SVO Forum
Fuel Pump?
Old 09-09-2009, 05:35 PM
hollcraft1
hollcraft1's Avatar
Default Fuel Pump?
I have spent a lot of money on this stupid car and am getting very frustrated. I am on my second Walbro 255 fuel pump and I think it is bad. At idle I am running about 39 psi with the vaccum line off fpr. What is the pressure suppose to be? Before this I thought I was too rich because I have 42 lb injectors in it. When I take the second pump off the rail the car getts no gas from the walbro 255 pump. But when I put it back on I get gas. How is that possible? Is there another 255 pump for the 2.3 turbo or should I just go back to the factory pump in tank and run two pumps? Please help I am lost.
Thank you
hollcraft1 is offline
Old 09-10-2009, 10:35 AM
fast65
fast65's Avatar
Well when you do the Walbro conversion you're supposed to just take the chassis mounted pump off. After you remove the chassis mounted pump then replace it with a fuel filter or some fuel line and ground the resistor wire from the chassis mounted pump (search around SVOCA for better instructions). That could be the root of your problems, because if you didn't ground that resistor wire I imagine that the Walbro just won't pump when you take the chassis mounted pump off. Here are a couple of threads that kinda detail what you need to do:
fast65 is offline
Old 09-11-2009, 07:54 PM
mg man 75
mg man 75's Avatar
May want to also check for kink fuel line. A buddy in KY just found a problem in his was a kinked return line. It was hide under a piece of rubber hose. Thought that might help someone else. I spent most of a day with him. We solved a bunch of issues but he found this one on his own.
mg man 75 is offline
Old 09-15-2009, 07:09 AM
NavySVO
NavySVO's Avatar
If you haven't done the resistor wire mod (84 and 85 SVO only) then you are burning up the pump. It will not pump fluids correctly either.
FP should be 39 w/o vacuum to the regulator.
There is no reason that you cannot have adequate fuel supply by using the dual pump setup. It actually will deliver more fuel at more than adequate pressure than that of the single in tank pump. It has already been proven.
BTW, you are going to run too rich with 42lb injectors unless you have a J chip or a stand alone system.
NavySVO is offline
Old 10-24-2009, 03:55 PM
Slow84SVO
Slow84SVO's Avatar
Ford says 38-42psi at rail with out vac attached is in spec. you need to run what ever is stock for the eec you have(injectors to ecu). you have aftermarket LOW impedance 42# injectors? high impedance will eat your injector drivers.
Slow84SVO is offline
GimpyHSHS
19
12-19-2023 01:12 PM
Bokeo
10-10-2015 08:28 PM
b8checker
10-08-2015 12:55 PM
Sixx
10-05-2015 07:36 PM
mrappe
09-26-2015 10:16 AM
Quick Reply: Fuel Pump?
