Wheels and Ride Height
Old 01-31-2014, 12:59 PM
  #141
rwcstang
rwcstang's Avatar
Originally Posted by cavelle
Hi, you only droped the front, or the rear 1" too ?
Frank, Germany
to whom are you referring to?
rwcstang is offline
Old 03-22-2014, 03:45 PM
  #142
guitarman376
guitarman376's Avatar
Wanted to update my car in this thread.
1.5" upper arm drop, kyb gas a just front stock rear shocks
opr roller track arms, 70' spindles
1 coil cut
4.5 reverse eye leafs
235/17/45 tires
guitarman376 is offline
Old 03-22-2014, 03:46 PM
  #143
guitarman376
Old 04-14-2014, 10:51 AM
  #144
dragman72
dragman72's Avatar
I am running 14's on mine. Just re did the entire suspension back to factory specs, but now I am thinking I may want to bring the back end up a little. What do you all think??
I don't have a pictures of the car on the perfectly level so it does look a little worse than it is.
Attached Thumbnails Wheels and Ride Height-mustang-1.jpg   Wheels and Ride Height-mustang.jpg
dragman72 is offline
Old 06-24-2014, 11:28 PM
  #145
rwcstang
rwcstang's Avatar
recent pic
rwcstang is offline
Old 11-18-2014, 07:55 PM
  #146
karuzho
karuzho's Avatar
hey man. please i need your help
karuzho is offline
Old 11-18-2014, 08:04 PM
  #147
karuzho
karuzho's Avatar
Default hey 1slow67
Originally Posted by 1slow67
1967
205/65R15 fronts and 215/65R15 rears
15x7 Cragar D Windows 4" backspacing
Stock suspension
shelby drop
1967
205/60R16 fronts and 235/60ZR16 rears
16x7 Pony Rims 4.8" backspacing running 1" wheel adapters all around
Stock suspension
shelby drop
(loved this set)
hello 1slow67 i see you use a pony wheels on your 67. i want to put ponys on my 67 but its 5 lugs. tell me how you did it.??? or your 67 its 4 lugs.??
karuzho is offline
Old 11-19-2014, 02:59 AM
  #148
1slow67
ROTM Moderator
1slow67's Avatar
Mine was 4 lug, but i still had to use adaoter plates because the bolt pattern was different.
However you can get a set of 5 lug pony wheels from PonyR. You will most likely need spacers to run them.
http://www.ponyrparts.com/index.php?...851fe9c838f2cf
1slow67 is offline
Old 11-19-2014, 10:49 PM
  #149
karuzho
karuzho's Avatar
Smile
Wowww % lug pony wheels... yeahhhh thanks man...
karuzho is offline
Old 11-20-2014, 05:13 PM
  #150
69mach1377
69mach1377's Avatar
Anybody running US Mags Bandit wheels?
69mach1377 is offline
Quick Reply: Wheels and Ride Height
