'67 4 lug
Old 09-18-2009, 03:20 AM
67mustangreg
67mustangreg's Avatar
Default '67 4 lug
is 4x4.5 the same as 4x 114.3??? I've seen some rims in 4x 114.3 that would look sick on my car.
67mustangreg is offline
Old 09-18-2009, 03:22 AM
67mustangreg
also, they are 18 x 8 ..whats that mean height x width?
Old 09-18-2009, 03:28 AM
andrewmp6
andrewmp6's Avatar
No 4x 4.5 is different then a 4x 114.3 18x8 means 18 inches tall 8 inches wide.
andrewmp6 is offline
Old 09-18-2009, 03:34 AM
67mustangreg
8 inches tall, jesuss....I must be tired...lol...
how is it not the same? I was looking at them and they all say 4x 114.3 will fit 4 x 4.5
Old 09-18-2009, 06:19 AM
JamesW
JamesW's Avatar
4.5" = 114.3mm
Other than the obvious issues with an 18x8 wheel and some outlandish backspacing, why wouldn't they fit?
JamesW is offline
Old 09-18-2009, 06:21 AM
2+2GT
2+2GT's Avatar
114.3 mm is "metric" for 4.5 inches.
2+2GT is offline
Old 09-18-2009, 06:48 AM
1slow67
ROTM Moderator
1slow67's Avatar
Yeah, they are the same.
1slow67 is offline
Old 09-18-2009, 09:29 AM
Norm Peterson
Norm Peterson's Avatar
114.3mm = 4.500". That means it will bolt up, assuming that nothing interferes with getting the wheel flat against the drum or disc hat, and that the holes are the proper size for your lugs.
The 18 is the nominal wheel diameter and tire size. It's not the OD of the wheel all the way out at the edges of the flanges, but somewhere in the bead seat inside the flanges down at the "barrel" of the wheel. Overall wheel OD is a little more than an inch and a quarter bigger than the "nominal" size. The 18" wheel on my '08 GT actually measures 19.5" overall.
Likewise, the 8" is an inside measurement between bead seat locations. The outside width will be about an inch greater.
Norm
Norm Peterson is offline
Old 09-18-2009, 09:40 AM
waldo786
waldo786's Avatar
Like everyone else said they are the same measurement. Make sure the rims are for a rear wheel drive application though. When I first started looking at rims and such I didn't know there was a difference but there is, so something to be aware of. I found some really cool rims that wouldn't work b/c they were for front wheel drive. They do sell a styled steel wheel hubcap with different color center caps that go on your 4.4.5 rims to make them look 5 lug. That's the way I'm going. Hope that's helpful.
waldo786 is offline
Old 09-18-2009, 09:51 AM
67mustangreg
Reason I ask: http://seattle.craigslist.org/est/pts/1377365096.html
or these 5 spoke: http://seattle.craigslist.org/tac/pts/1372170838.html
Oh, snaps! I didn't know that. So, what's the differance in rims between RWD and FWD?
Quick Reply: '67 4 lug
