Whats the best Camshaft for my 04 GT???
Old 09-18-2009, 07:24 AM
yunior0114
yunior0114's Avatar
Post Whats the best Camshaft for my 04 GT???
Hi everyone, i have an 04 mustang gt with regular bolt ons, 75mm TB, Plenum, Pulleys, 3.73 Gears, Full exhaust, Diablo tuner, air intake, 150 shot of nitrous. So here is the big question, what cam do you goes recommend??? i dont want to change the valve springs on the heads, i just want a cam where i can just bolt on and not tune. ive heard that compa cams 1 is a good one to go with. Help me out guys, really apreciate your replies. thanks
yunior0114 is offline
Old 09-18-2009, 07:27 AM
bigmike0405
bigmike0405's Avatar
bigmike0405 is offline
Old 09-18-2009, 07:31 AM
99BlackPonyGT
aka 'Negative Nancy'
99BlackPonyGT's Avatar
since you dont want to change springs, and youre spraying...i would call CMS and ask them what they reccomend for you, they can probably make you a stage 1 cam thats nitrous specific....no matter what cams you get though, you will need to have the car dyno tuned...and i reccomend replacing the springs...but its not my motor....goodluck
also, for a 150 shot you should be dyno tuned as well...the most ive heard the stock tune being good for is a 100 shot. dont wanna lean it out and blow it up
99BlackPonyGT is offline
Old 09-18-2009, 07:44 AM
mrtstang
mrtstang's Avatar
I'm in the same situation as you. I have a bolt on 04 gt with a 100 shot, and want a set of cams that i don't have to change the springs on. I've done countless hours of research in this area as well.
I'm going with Bullet Racing cams. Call Nick at Modular Head Shop. He has Bullet grind them to his specs, and they have some really nice grinds that don't require a spring change, and work well n/a or with nitrous.
mrtstang is offline
Old 09-18-2009, 08:12 AM
Sxynerd
Sxynerd's Avatar
Cushman Motorsports stage1 NA cams! Hands down
http://www.cushmanmotorsports.com/in...b9a44201f081b6
Sxynerd is offline
Old 09-18-2009, 10:58 AM
GTRACER88
GTRACER88's Avatar
I would never do stage 1 cams. If I'm going to spend the money I would make it stage 2 as a minimum. Check out hitech stage 2.
GTRACER88 is offline
Old 09-18-2009, 11:16 AM
Roush2002
Roush2002's Avatar
first thing is make sure you know what your future power plans are for the car. Go from there.
Roush2002 is offline
Old 09-18-2009, 11:23 AM
0949er
0949er's Avatar
why would you not take the next step and just buy stage 2? you will hardly get the cam "lope" with a stage 1 cam, or the real performance you want. Even my stage 2's are "fairly" mild in regards to cams.
BTW, REPLACE YOUR VALVE SPRINGS. DON'T CHEAP OUT. ESP IF YOU DO STAGE 2. IT IS AS IMPORTANT THE CAMS ITSELF.
0949er is offline
Old 09-18-2009, 11:25 AM
Sxynerd
Sxynerd's Avatar
+1 Bingo!
Me for example: All I wanted was 300 but it was cheaper to make 400 with a blower. Then I blew my engine. Then it was just a plain rebuild....$8,000 later I've got a 600rwhp (ish) car sitting in my garage collecting dust because it's too fast and I should have had more realistic goals for the type of driver/racer I am.
Sxynerd is offline
Old 09-18-2009, 11:32 AM
0949er
0949er's Avatar
Originally Posted by sxynerd
+1 Bingo!
you poor thing.... I feel so bad for you......
0949er is offline
Quick Reply: Whats the best Camshaft for my 04 GT???
