Old 10-22-2015, 02:34 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Ford Mustang Specifications & General Maintenance
Print Wikipost
Replacing brakes-Mustang v-6, 2003
Old 10-17-2009, 03:47 PM
LGDiaz
LGDiaz's Avatar
Question Replacing brakes-Mustang v-6, 2003
Hi every body. I am new to the Forum and I am siking help to install brakes, front and rear, on my v-6cylinder Ford Mustang 2003. Appreciate all the help I can get
LGDiaz is offline
Old 10-17-2009, 04:03 PM
Shaunmac9128
Shaunmac9128's Avatar
Its pretty simple. Take your wheels off. unbolt the calipers. take out the old brake pads. use a c clamp to compress the pistons. put in new brake pads. slide caliper back over. if it doesnt fit continue to compress the pistons with a c clamp using the old brake pad to distribute even pressure on the pistons. make sure you put anti squeal on the back on the brake pads as well. then bolt it all back up. backs you need some tool i think i havent done the rears before.
Shaunmac9128 is offline
Old 10-17-2009, 04:11 PM
TurtleSLow
TurtleSLow's Avatar
yeah there is a special tool for the rear calipers, you should be able to find it at a parts store or something. basically it goes on a ratchet and you turn it so it backs back in
TurtleSLow is offline
Old 10-17-2009, 05:03 PM
LGDiaz
LGDiaz's Avatar
Thank you guys...TurtleSlow and Shaunmac9128 for your responses. I have found something tthat will help all of you, like myself, is doing this job for the very firs time....look at this video. Yes you need a special tool to compress the calipers...check it out....
http://www.youtube.com/watch?v=TpeKWzdnfkQ
Luis D.
LGDiaz is offline
Old 10-17-2009, 05:13 PM
Shaunmac9128
Check your pm's as well.
Old 10-17-2009, 07:29 PM
Mirage
Mirage's Avatar
Are you looking to change the entire system (calipers, rotor, pad and lines), or just the pads? The front brake pads are prety self-explanitory, just do what Shaunmac said and you'll be fine.
Mirage is offline
Old 10-17-2009, 08:29 PM
LilRoush
LilRoush's Avatar
Don't waste money on a special tool for the rears. Use needlenose pliers to twist the piston back into the caliper. I've done it dozens of times. When you have it apart, you'll see what I mean.
LilRoush is offline
Old 10-17-2009, 10:39 PM
Fink
Fink's Avatar
This.
Only retards buy the tool.
Fink is offline
Old 10-18-2009, 01:27 AM
neo8222
neo8222's Avatar
i just used my big c clamp cause when u tighten it it also turns... worked fine for me... i did buy one of those cheap 4 dollar tools and chucked it into the woods about 2 tries after buying it lol used the clamp instead.
neo8222 is offline
Old 03-11-2011, 02:48 PM
99'PEGASV6
99'PEGASV6's Avatar
can someone tell me the exact tools/process I need to do this?
1999 v6 manual trans.
remember, i really don't know anything!
I've got a C clamp.
or does that video pretty much explain what I have to do; idk if brakes systems are different.
99'PEGASV6 is offline
Quick Reply: Replacing brakes-Mustang v-6, 2003
