Motor Swap Section Tech and Follow-My-Build Threads for members looking to put a different engine in their Mustang
Step by Step guide to installing a Mark VIII motor in a 96+ GT.
Old 02-12-2010, 07:52 PM
  #21
JC316
JC316's Avatar
Originally Posted by offthewall158
Any track times or dyno numbers?
Not yet. Got it finished right as the season was getting wet and cold, so I haven't had a chance to run it.
JC316 is offline
Old 02-12-2010, 08:32 PM
  #22
AJB540
AJB540's Avatar
Does the Mark VIII has forged internals? Around how much HP could I build it up to?
AJB540 is offline
Old 02-12-2010, 09:10 PM
  #23
JC316
JC316's Avatar
Nope. They use the nodular iron crank and the same crappy pistons/rods as every other 4.6l 2v from those years. Stock, you can take it to 450ish rwhp, built, I have seen 1000HP monsters. The beauty of it is that the Mark VIII uses the Teksid block.
JC316 is offline
Old 03-01-2010, 08:35 PM
  #24
spruytte24
spruytte24's Avatar
I am getting ready to do this swap into a 2001 gt with a 5sp. I have a 97 mark viii 4.6DOHC along with the pcm and wiring harness. Here are my questions.
Can I re-use my clutch? Spec stage 3 with 10k miles on it..don't wanna have to get another one. If I can't, what clutch do I need? Also what flywheel do I need? I have the tr3650 tranny.
Just to clearify that the stock gt computer and harness will work with the mark viii engine with a few modifications to the harness?
Thanks.
spruytte24 is offline
Old 03-01-2010, 10:09 PM
  #25
JC316
JC316's Avatar
Thanks.
In 01, it should be the 6 bolt flywheel that's attached to your engine, so you can use the stock one, or any 6 bolt flywheel for an 01-04 mustang. You should be able to reuse the clutch as well, just so long as it attaches to the flywheel.
Yes, I am still running a GT computer and a GT tune with my engine.
JC316 is offline
Old 04-07-2010, 01:48 PM
  #26
liljojo4711
liljojo4711's Avatar
any updates on this? new track times or anything else i should know before starting the build? if i get a high mileage motor, what are some things i should replace in order to make it reliable? anything big difference between getting a 97-98 vs 93-96 engine?
basically all 96-98 cobra parts are what i would be looking for from now on correct? cams, heads, headers, intakes, pistons, rods and all that?
liljojo4711 is offline
Old 04-07-2010, 08:10 PM
  #27
JC316
JC316's Avatar
Still no track numbers, the weekend I was going to go, I sprung a water leak. The biggest difference in the 97+ motors is the intake, to save a headache, you really want the 97+ intake, or a cobra intake. The motor should be reliable. And yeah, all part will be for a Mark VIII or a cobra.
JC316 is offline
Old 04-08-2010, 12:50 AM
  #28
GTRACER88
GTRACER88's Avatar
Is this a sticky yet??? Awesome write up!
GTRACER88 is offline
Old 04-08-2010, 01:21 PM
  #29
liljojo4711
so if im planning on a cobra intake anyway it doesnt matter. are there any differences between the 93-98 mark heads and the 96-98 cobra heads?
Old 04-08-2010, 01:30 PM
  #30
liljojo4711
double post
Quick Reply: Step by Step guide to installing a Mark VIII motor in a 96+ GT.
