brakes lock up easy
Old 11-02-2009, 08:01 PM
88GTBLACK
88GTBLACK's Avatar
Default brakes lock up easy
I got newer front and rear brakes ALL STOCK drums and all. I just dont feel like I can stop quick and i usually lock up the front tires pretty easy usually the front right. Do our foxes brakes suck that bad stock??
Newer front rotors newer pads 90% rear drums are 85% all new hardware.
Pedal is pretty solid brake lines dont leak theyre rusty as hell though. I'm undercoating my car next weekend.
WTF why do I feel like im never going to stop fast and i lock up if i try to hard to slow down.
88GTBLACK is offline
Old 11-02-2009, 08:15 PM
dreamer1uk
dreamer1uk's Avatar
Hi,
Id check the front calipers to make sure the piston is not binding. I would also do a visual check on the brake hose going to the calipers, checking for bulges, kinks and such, particulary on the right side of the vehicle.
dreamer1uk is offline
Old 11-02-2009, 11:21 PM
mattdel
mattdel's Avatar
air in the lines will cause a premature lockup as well.
mattdel is offline
Old 11-03-2009, 01:36 PM
67mustang302
67mustang302's Avatar
Bleed the brakes, also pads need to be bedded properly as well. But get better tires. Brakes don't stop the car, they stop the wheel from rotating. Tires stop the car. The best brakes in the universe are completely useless without tires that have effective grip.
67mustang302 is offline
Old 11-03-2009, 01:55 PM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
Fox brakes are not THAT bad. Just gotta know how to adjust them and keep them in check.
projectresto83 is offline
Old 11-03-2009, 06:44 PM
Styg
Styg's Avatar
Brakes on Fox bodies are inadequate in the stock form, there is no way around that. You have pinto drum brakes on the rear, and no ABS. Give the car in front of you some room and hope for the best.
Styg is offline
Old 11-03-2009, 07:29 PM
Bubba 95SN
Bubba 95SN's Avatar
The front brake that locks up is the one that is hitting last. That wheel is spinning faster and when the brake goes on it locks up. Does the left side have drag? More information . Wheel cylinders in rear-new? Check behind dust cover for leaks. Rear adjusters ok? Rear adjusted proper?
Bubba 95SN is offline
Old 11-03-2009, 08:08 PM
88GTBLACK
88GTBLACK's Avatar
the scumbag f***ing redneck who i bought the stang from crimped the rear brake line going to the right rear tire I guess it was his way of fixing a leak, the right rear tire had no braking at all! This explains A LOT. Wait till I see this scumbag I think I still got his number and where he lives. Thanks for the help guys.
And this whole time im looking at the rear shoes front shoes new drum hardware new pads in all corners scratching my head like an idiot, never expecting a crimped brake line...dude...
Old 11-03-2009, 08:11 PM
mattdel
mattdel's Avatar
Originally Posted by 88GTBLACK
the scumbag f***ing redneck who had it before me crimped the rear brake line going to the right rear tire I guess it was his way of fixing a leak, the right rear tire had no braking at all! This explains A LOT. Wait till I see this dirtbag. Thanks for the help guys.
And this whole time im looking at the rear shoes front shoes like hmmm new drum hardware new pads in all corners and this is what I find. dude...
wow lol... hahaha
mattdel is offline
Old 11-03-2009, 11:03 PM
projectresto83
M.A.D. Motorsports
damn...... yea that will do it. I drove my car around with the rear brakes completely sucking. You will feel a huge difference with the rears accually working properly.
Quick Reply: brakes lock up easy
