Power steering leaking??
Old 11-14-2009, 06:38 PM
guitarist4life
guitarist4life's Avatar
ya. I gotta get a new PS rack myself. I too thought just the o ring could be replaced. But..NOPE. Silly ford
guitarist4life is offline
Old 11-14-2009, 07:20 PM
camaroeater
camaroeater's Avatar
Originally Posted by Boss_Hotrod
how did you put the washer on? they should have been so tight you could barely get them over the threads. The last one I did it got it to start on one thread and then walked it up the rest while I was installing it. Still hasnt leaked. That was on a ranger. On my Mustang Im running stainless lines and o-rings (yeah they hold). However DO NOT put a rubber o-ring on the stock lines or you'll have a squirter!!
I heated them up to slip them on the end, then threaded them on the rest of the way. I'm pretty sure these lines don't use teflon seals, if anything, maybe thread sealant.
camaroeater is offline
Old 11-14-2009, 08:01 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Originally Posted by camaroeater
I cleaned everything real good and used a wire brush. I tried tightening them more and it didn't help. Im thinking that the 2 lines that are ALL steel do not need teflon seals like the pressure and return lines. I did not see any traces of a seal when i removed them. Does anybody know how to properly seal these steel lines? Maybe with teflon tape or thread sealant? thanx...
only 2 of the lines have teflon seals, the pressure and return into the rack
mjr46 is offline
Old 11-15-2009, 01:50 AM
camaroeater
I gonna remove all 4 lines and only put seals on the pressure and return line, thanks.
SSRFUZZY
Members Other Vehicles
01-06-2016 08:22 PM
uberstang1
09-20-2015 06:42 PM
BOBCATJACK
09-14-2015 02:18 AM
MusicCity615
09-12-2015 07:05 AM
Quick Reply: Power steering leaking??
