GT500 Sway Bars
Old 11-16-2009, 02:43 PM
heartinacage
heartinacage's Avatar
Default GT500 Sway Bars
I found some GT500 sway bars for fairly cheap. I was considering buying them, but think I remember reading the rear bar may be too large for my car (V6). Can someone with knowledge enlighten on this?
I have a brand new FRPP rear sway bar in my garage, but can't seem to find the right hardware for a decent price.
heartinacage is offline
Old 11-16-2009, 04:13 PM
nemosgt
nemosgt's Avatar
Too large to fit or too large for safe handling?
If the latter, it might be because the Shelby plows more than the others and needs a larger rear bar to decrease the understeer. On the six it may lead to more oversteer than you want.
Just my musings. Maybe others with more experience will chime in.
Cheers.
nemosgt is offline
Old 11-16-2009, 09:00 PM
heartinacage
Too large for safe handling. I can't seem to find the thread i'm looking for.
Old 11-17-2009, 10:30 PM
Rubrignitz
Rubrignitz's Avatar
When you say "hardware".. what hardware is required to mount a GT/500 rear bar to a V6 stang? just wondering because I have the entire rear setup from my GT and can help you if you need some parts.
Rubrignitz is offline
Old 11-18-2009, 12:47 AM
heartinacage
I don't have bushings, end links or the brackets to hold the ends of the sway bar. These GT500 sway bars I'm looking at have everything I need.
Old 11-18-2009, 07:26 AM
Rubrignitz
Rubrignitz's Avatar
Ah, I see. I have the complete stock GT front and rear swaybar assy's in my garage removed when I installed the Hotchkis setup. I need to post again on craigslist, see if a V6 owner needs them. I posted a while back with a huge "05-09 mustang V6 owners - swaybars" header but no bites...
Old 11-19-2009, 01:48 PM
bronxbomba63
bronxbomba63's Avatar
Rubrignitz, where in TX are you?
bronxbomba63 is offline
Old 11-19-2009, 03:52 PM
heartinacage
Ill hoping someone can answer my question.
Old 11-19-2009, 06:18 PM
Rubrignitz
Rubrignitz's Avatar
I'm in austin. Why wouldn't the GT500 bars be safe??? You have an S197, the GT500 bars are going to be a huge improvement. Just because someone doesn't like the "feel" of a larger front/rear bar doesn't mean it's not "safe".
I run hotchkis which are massive 1.5'' front/1'' rear and my car handles great. A little more about how swaybars work. Are you auto-x'ing the car? Do you have aftermarket springs? It sounds like you just want a rear bar....
http://www.houseofthud.com/cartech/swaybars.htm
Old 11-20-2009, 01:48 AM
heartinacage
I have the FRPP dampers and springs. I plan on autocrossing the car after I finish the suspension.
Quick Reply: GT500 Sway Bars
