VACUUM LEAK PLEASE HELP!!!!
Old 11-18-2009, 12:50 PM
saveme20
saveme20's Avatar
Default VACUUM LEAK PLEASE HELP!!!!
I have a 2001 mustang gt and i sounds like it has a vacuum leak and it goes in and out I tried to find it before and couldn't find anything but yesterday I found out where its coming from I guess it's some type of a valve right in front of the throttle body its rectangle and about an inch tall and 2 inches long. It sounds like it's opening and closing but I have no idea what its called and I'm guessing it not suppose to sound like that If any has had this problem or knows what it is PLEASE let me know.
saveme20 is offline
Old 11-18-2009, 01:45 PM
mrtstang
mrtstang's Avatar
I was going to say the pcv valve, but that's on the passanger side valve cover. Are you sure it's not coming from there?
mrtstang is offline
Old 11-18-2009, 01:49 PM
masterofthepuppets99
masterofthepuppets99's Avatar
helmholtz device?
masterofthepuppets99 is offline
Old 11-18-2009, 01:56 PM
saveme20
saveme20's Avatar
positive i guess ill go to ford and see what they say
saveme20 is offline
Old 11-18-2009, 02:10 PM
saveme20
saveme20's Avatar
If you look below step 11 you will see a black rectangle box that attaches to the throttle body in the corner of the pic thats where the sound is coming from
saveme20 is offline
saveme20
saveme20's Avatar
http://images.google.com/imgres?imgu...a%3DN%26um%3D1
saveme20 is offline
Old 11-18-2009, 02:20 PM
pinto18
pinto18's Avatar
Have you done the rev modd by changing your gasket in your IAC ?? Which is what that black box is connected to. If so then i believe it should sound like that and its not a leak
pinto18 is offline
Old 11-18-2009, 03:01 PM
03BottleFedGT
03BottleFedGT's Avatar
take off the black box and replace it with a hose you dont need it
03BottleFedGT is offline
Old 11-19-2009, 01:39 PM
Brute03
Brute03's Avatar
if you're hearing intermittent sucking noises around that "black box", then its more than likely just the IAC regulating the idle. pretty normal
Brute03 is offline
Old 11-20-2009, 01:28 AM
rafacalz
rafacalz's Avatar
What is the point of taking it off?
rafacalz is offline
Quick Reply: VACUUM LEAK PLEASE HELP!!!!
