Auto Tranny Stuck In Park
Old 01-06-2010, 10:41 AM
carockwell
carockwell's Avatar
Default Auto Tranny Stuck In Park
My auto trans 2007 is stuck in Park, the lever will not move onto any other position. Anybody have this problem before?
carockwell is offline
Old 01-06-2010, 11:25 AM
157dB
Cut & Paste Expert
157dB's Avatar
Put your foot on the brake pedal and depress it first...
Or read the owners manual...
Anyone done that before.....
157dB is offline
Old 01-06-2010, 03:43 PM
chronos
chronos's Avatar
We don nee no stin kin owners manual! However, if he had read it he would have found that the little tab next to the shift handle is there for a reason, hint, hint....
chronos is offline
Old 01-06-2010, 03:48 PM
alkemist
alkemist's Avatar
r3ading is hArd. I come here to look pretty pictures. Manual is good for keeping bag of chips shut.
I thought that button was to turn on/off O/D? Though I do remember reading something about a lock and automatic around that area, needed a key or something?
alkemist is offline
Old 01-06-2010, 09:59 PM
stealth_GT
stealth_GT's Avatar
open up the little tab next to the shifter, your key should fit in there to unlock the shifter. If not use an alley wrench.
jk, don't use that.
How the heck did it get stuck in park?
stealth_GT is offline
Old 01-06-2010, 10:16 PM
carockwell
carockwell's Avatar
The problem has been intermittant for a while, this time it really got me stuck. You are telling me if I lift up the trim around the shifter I should see some allen head bolt that needs some tweaking?
Old 01-06-2010, 10:20 PM
stealth_GT
stealth_GT's Avatar
should be a key hole so you can turn the key and unlock the shifter.. it's only a temperary fix though...
Old 01-06-2010, 10:26 PM
alkemist
alkemist's Avatar
Read page 151 of this manual. This is for a 2006 but should be virtually the same between '05-'09.
http://www.evergreenford.com/quickQu...06/Mustang.pdf
alkemist is offline
Old 01-07-2010, 09:57 AM
chronos
chronos's Avatar
The little silver plug on the trim surround (opposite the letter "D") lifts up to magically reveal a release for the shifter.
chronos is offline
Old 01-16-2010, 09:01 AM
157dB
Cut & Paste Expert
157dB's Avatar
You dont 'turn the key'.
You remve the trim piece over the slot that you
are suppost to insert something long and skinny
(guess what, like the key, but anything long and
skinny will work. You are pressing a spring loaded
plastic locking tab thats internal to the shifter assembly.
An electric solenoid usually does this when you depress
the brake pedal. If you try and pull the shifter out of park
before depressing the brake pedal, the locking tab wont
allow it but depress the pedal before attempting to remove
the shifter from the park position and the solenoid pulls the
spring loaded locking tab out of the way and the shifter releases.
If you attempt to remove the shifter from park and then depress
the brake pedal, the locking tab becomes locked in that position
and the solemoid does not have enough uummmph to pull it
out of the lock position until you release the tension on the shifter
handle. Trying to get it out of park before pressing the brake pedal
over and over puts undue wear and stress on this plastic part and it
get worn to the point where it wont release with the solenoid.
Remove the plastic locking arm and enjoy being able to take her
out of park without your foot on the brake pedal.
157dB is offline
mungodrums
09-28-2015 10:54 PM
wraith777
09-28-2015 10:49 AM
Sixer4Life
09-28-2015 07:05 AM
treesloth
09-28-2015 07:03 AM
2poor4u2
09-26-2015 11:08 AM
Quick Reply: Auto Tranny Stuck In Park
