Blocking off waterpump heater hoses
Old 02-02-2010, 06:30 AM
holyshift
holyshift's Avatar
Default Blocking off waterpump heater hoses
Has anyone ever blocked off there heater hoses on their water pump?? If so how?I dont need it anyways considering the only time I drive my car is in the summer.
holyshift is offline
Old 02-02-2010, 06:45 AM
TrimDrip
FudgeDrip
TrimDrip's Avatar
heater core and why do it if it works and doesn't leak?
TrimDrip is offline
Old 02-02-2010, 09:21 AM
Tony71502
Tony71502's Avatar
To clean up the engine bay and remove two hot coolant lines running across the intake manifold.
I bypassed the heater core but I just ran a hose from the water pump directly to the intake manifold.
I thought I wouldn't drive in the winter either... now I'm hooking it back up.
Tony71502 is offline
Old 02-02-2010, 09:22 AM
primetime5.0
primetime5.0's Avatar
I bought big rubber caps from vatozone and blocked them off
primetime5.0 is offline
Old 02-02-2010, 10:32 AM
holyshift
holyshift's Avatar
+1 to cleaning up the engine bay and trust me my car wont be out in the winter. Anyways did you just hose clamp the caps on??Were they just big vacuum caps?
Old 02-02-2010, 12:44 PM
golden_eye
golden_eye's Avatar
I did this on my old truck by cutting a small part of heater hose and just looping it from one side of the pump to the other. Probably only needed about 6 inches of hose.
golden_eye is offline
Old 02-02-2010, 01:01 PM
Tony71502
Tony71502's Avatar
Foxes have a line going from pump to EGR spacer and heater core. Then both lines return to the intake manifold.
The heater core has two diff sized hoses, so you'll have to run the water pump sized hose to a custom fitting on the intake. Or, what I did, was run an oversized hose from the water pump to the stock intake manifold fitting that I cut off of the original two steel hardlines.
Old 02-02-2010, 01:11 PM
TrimDrip
FudgeDrip
TrimDrip's Avatar
so the temp sensor just screws in that special fitting after all that removal? I have never seen anyone do this on a fuel injected motor.
TrimDrip is offline
Old 02-02-2010, 01:47 PM
holyshift
holyshift's Avatar
This is a carb'd car,but anyways Ive heard of primetimes idea up there just didnt know were to get such caps from,but whats the temp sensor have to do with this?
Old 02-02-2010, 02:01 PM
mattdel
mattdel's Avatar
people always seem to confuse A/C lines with heater lines.. there isn't, and shouldn't be a sensor in the heater lines. the two sensors that are in coolant passages are both in the intake, for EFI.
mattdel is offline
Quick Reply: Blocking off waterpump heater hoses
