Old 10-08-2015, 01:29 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Powertrain Guides
Print Wikipost
4.6 starter removal???? i have no idea
Old 02-09-2010, 12:45 PM
chrisgtr
chrisgtr's Avatar
Default 4.6 starter removal???? i have no idea
so to unbolt my exhaust (to ultimately pull the motor) i need to take off the starter. which if you can imagine 9 panda bears in a vw beatle and you trying to reach your keys under the front seat.... thats about how much room there is to get tools up in there... input much appreciated
chrisgtr is offline
Old 02-09-2010, 12:49 PM
Donnie's GTS
Donnie's GTS's Avatar
its actually really easy. there are only two bolts, the bottom one you can get out with a socket and ratchet, the top you'll need some extensions, and can get at it in front of the k member, just get under there and take a look.
And, if your're removing your exhaust, you don't need to take the starter off.
your analogy is way off btw lol.
Donnie's GTS is offline
Old 02-09-2010, 03:52 PM
StangManBen
StangManBen's Avatar
I took mine off when I hooked up my offroad x-pipe, it really isn't bad at all. Getting to the bottom manifold bolt on the passenger side was a bit more of a pain, but certainly doable. And, he's right. If you're pulling the motor, why remove the starter. Just get the two bolts off your intake manifolds on each side and your exhaust is done.
StangManBen is offline
Old 02-09-2010, 04:02 PM
doughboy4.6
doughboy4.6's Avatar
Your car must have been worked on before if it only had 2 bolts in the starter lol. There are 3 bolts in the starter most guys get lazy and only put 2 back in. The last one is a bitch to get back in.
doughboy4.6 is offline
Old 02-09-2010, 09:09 PM
texas_stang02
texas_stang02's Avatar
yeah there are two bolts on the bottom and one on the top. i had to replace my starter a few months ago, and much to my surprise, after the 2nd bottom bolt came out so did the starter. the shop that built my engine last year must have just left the top bolt off. i used a swivel ratchet and several different extensions and it wasn't too bad to get to all the bolts.
texas_stang02 is offline
Old 02-09-2010, 10:03 PM
chrisgtr
chrisgtr's Avatar
Default thanks..
i didnt think about goin through the k member. and yea there is THREE bolts. the bottom two didnt so much bother me. its the third one that is a pain. but thanks for the help
chrisgtr is offline
Old 02-09-2010, 10:05 PM
Gearhead559
Gearhead559's Avatar
3rd one is right on top...hard to see, from under neath..unless you use a mirror
Gearhead559 is offline
Old 02-09-2010, 10:11 PM
volcomchester18
volcomchester18's Avatar
swivel joints helps. I used to work at ford as a mechanic and even with all the tools it can be a pain, especially the third bolt. Just got to be patient.
volcomchester18 is offline
SSRFUZZY
Members Other Vehicles
01-06-2016 08:22 PM
wawagner82
09-13-2015 09:02 AM
wilsonro
4 Cylinder NA and Turbo
09-11-2015 07:13 AM
angeljoelv
SVT Forums
09-10-2015 09:12 PM
vintageaion
09-08-2015 10:45 AM
Quick Reply: 4.6 starter removal???? i have no idea
