Old 10-26-2015, 02:31 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Powertrain Guides
Print Wikipost
Oil leaking from the top of the coil?
Old 02-18-2010, 03:26 AM
nba1341
nba1341's Avatar
Default Oil leaking from the top of the coil?
Ok so I just noticed that there is a little bit of oil at the top of my coil. I first noticed a tiny bit on the bottom of it (leaked down from the top) when I was changing my starter.
Why would my coil be leaking oil? And is it going to die soon?
P.S. Orig had a flamethrower coil and it died on the freeway so I had to buy one from auto zone and got an accell one exactly 1 year ago. So this accell coil is 1 year old.
nba1341 is offline
Old 02-18-2010, 03:45 AM
67mustang302
67mustang302's Avatar
Coils are transformers. The oil helps to cool them. If it's leaking it will need to be replaced, since air will get in and the oil will vaporize into the air pocket, mix, and probably ignite, and your coil will explode...or at least burn up in flames.
That's what causes some transformer explosions(oil filled ones anyway).
67mustang302 is offline
Old 02-18-2010, 04:12 AM
nba1341
nba1341's Avatar
should i get another oil filled one? Also what brands are recommended?
nba1341 is offline
Old 02-18-2010, 04:19 AM
tx65coupe
tx65coupe's Avatar
I agree, it needs to be replaced soon.
What distributor / ignition are you running? Do you have the Pertronix Ignitor? It can make a difference which coil to get, since they come in different resistance values.
Do you remember if you had a Flamethrower or Flamethrower II coil before?
Where do you have it mounted? I relocated mine to the inner fender to keep the engine heat away from it.
tx65coupe is offline
Old 02-18-2010, 04:22 AM
nba1341
nba1341's Avatar
its a motorcraft distributor. coil was a flamethrower 1 oil filled before.
nba1341 is offline
Old 02-18-2010, 03:48 PM
67mustang302
They're all oil filled to my knowledge. The non oil ones for industrial stuff are usually wrapped in porcelain. But a 220+KV power station transformer is quite a different beast from an automotive ignition coil.
Old 02-18-2010, 05:17 PM
nba1341
nba1341's Avatar
They sell that flame thrower one in a black unit on summit that is expoxy filled. Not sure what the function does.
nba1341 is offline
Old 02-18-2010, 06:35 PM
2+2GT
2+2GT's Avatar
The point of oil or epoxy filling is to allow heat transfer out of the coil, preventing hot spots inside. If yours is leaking oil, it's either defective, damaged, or has been run at excessive voltage. Before you spring for a new coil, check the voltage to the coil. I'd hate to see you fry the new one.
2+2GT is offline
Old 02-18-2010, 07:05 PM
nba1341
nba1341's Avatar
What voltage should it be getting? 12-14v im assuming?
nba1341 is offline
Old 02-18-2010, 07:11 PM
2+2GT
2+2GT's Avatar
Nope. More like 7V. 14V would certainly explain why the oil is fleeing the scene. The coil should only get the full 12V while the starter is engaged.
2+2GT is offline
Quick Reply: Oil leaking from the top of the coil?
