Where's the AC Relay?
Old 02-20-2010, 10:00 PM
liberty911
liberty911's Avatar
Default Where's the AC Relay?
Search showed nothing. My AC clutch is not engaging. I tried to jump the low/high pressure switch but nothing. Now I need to find the AC relay. Anyone know where it is?
liberty911 is offline
Old 02-20-2010, 10:46 PM
tx_zstang
tx_zstang's Avatar
In the underhood fuse/relay box. Now, which relay is it...the owner's manual shows a picture of the relays and fuses and a reference chart for which is for what. (dont have it handy to tell you which relay it is)
The relays are oriented in specific directions, and they are not all the same.
tx_zstang is offline
Old 02-21-2010, 06:46 AM
liberty911
liberty911's Avatar
I don't have the owners manual, but thanks for narrowing the location down.
Old 02-21-2010, 07:24 AM
Murphdog
Murphdog's Avatar
you can get the owners manual and other docs for free on the owner website here....
https://www.flmowner.com/servlet/Con...aining-vehicle
Murphdog is offline
Old 02-23-2010, 08:02 PM
red96v6
red96v6's Avatar
#24 Micro relay A/C clutch, under the hood.
Should show the position on the bottom of the cover.
Run a wire from the bottom left (passenger side close to front bumper) to the top right hole where the relay goes to bypass it.
Clutch should engage, I can hear and see mine click when this is done.
This is what the Ford Techs showed me to do.
I have the same problem as you, yet to find a solution.
red96v6 is offline
Old 02-24-2010, 10:51 AM
liberty911
liberty911's Avatar
Thanks that's some good info.
Update: I took all electrical and mechanical connections off. Cleaned, rechecked specs and reinstalled. Working perfectly know.
Old 02-25-2010, 07:17 PM
red96v6
red96v6's Avatar
What all did you take off and clean? Please explain. I want to try that also to see if mine will work properly...
red96v6 is offline
Old 02-26-2010, 08:11 AM
liberty911
liberty911's Avatar
AC clutch, the 2 electrical connections at the compressor and the connection at the low pressure sensor. I used electronic cleaner on the electrical connections, and re-torqued and re-gaped the AC clutch. Hope this helps.
Old 02-26-2010, 10:55 AM
157dB
Cut & Paste Expert
157dB's Avatar
tRY SEARCHING THE OWNERS MANUAL
thats in the glove box.
http://shnack.com/docs/mustang06.ownersmanual.pdf
157dB is offline
Old 02-26-2010, 09:31 PM
red96v6
red96v6's Avatar
Thank you, I will try this very soon, maybe tomorrow at work. Hopefully this will save me a trip to the dealership...
red96v6 is offline
Quick Reply: Where's the AC Relay?
