Electronic Pointless Distributor
Old 03-01-2010, 07:28 AM
classiccars
classiccars's Avatar
Default Electronic Pointless Distributor
I'm thinking about replacing the stock ignition system and going with a electronic pointless unit. (1966 289 v2) I want to keep the stock appearance. Is there a unit that fits under the stock distributor car?
Any suggestions? Someone said: Pertronix??
Thanks
classiccars is offline
Old 03-01-2010, 07:41 AM
1slow67
ROTM Moderator
1slow67's Avatar
Pertronix
Their setup goes inside the distributor to replace the points and the only things coming out of the dizzy from it are 2 wires. I ran it until I upgraded to a later model distributor last year.
1slow67 is offline
Old 03-01-2010, 07:59 AM
kalli
kalli's Avatar
ya. there's all different sorts. but i found the pertronix modules are easy upgrade
Pertronix I is outdated. pertronix II will have a fwe additional features like adaptive dwell and the newest pertronix III even a little dial for rev-limiting.
simple. make sure to check on the manual for information about the resistor wire
kalli is offline
Old 03-01-2010, 09:05 AM
chris66dad
chris66dad's Avatar
Take a look at this one. Ready to run, no external box needed. Will not work on a roller cam though.
http://www.professional-products.com/distributor.php
Thread from another forum:
http://www.gearheadtalk.com/forums/s...ad.php?t=23052
Alex at MoneyMakerRacing is selling them. I think around $250
chris66dad is offline
Old 03-01-2010, 07:51 PM
lefty3382
lefty3382's Avatar
I used to have an MSD Pro Billet Ready to run distributor (#8352) on my old engine. Loved that thing, never had a problem with it. I was going to get another one, but that Pro Products Powerfire looks really interesting, I like the timing adjuster **** idea. They're only $160 on Summit as well. Compared with $350 for the MSD unit. Very tempting...
Anybody running this unit?
lefty3382 is offline
Old 03-01-2010, 07:57 PM
1slow67
ROTM Moderator
1slow67's Avatar
Guys, he said in his post he wants to keep it looking stock.
1slow67 is offline
Old 03-02-2010, 09:15 AM
MBDiagMan
MBDiagMan's Avatar
If your goal is to eliminate the points and have a stock looking distributor, then Pertronix is a great solution. Keep in mind though, this is simply a points eliminator. It does not give a stronger spark than a properly operating points ignition. For that, your most economical solution is a Dura Spark set up out of the wrecking yard for a few bucks. It will give you a flame thrower, maintenance free ignition system for very little cash outlay.
MBDiagMan is offline
Old 03-03-2010, 03:17 AM
tx65coupe
tx65coupe's Avatar
I agree with the Pertronix Ignitor its an easy upgrade.
The Dura Spark distributor is a good way to go also and will appear nearly stock.
tx65coupe is offline
mrtrodonet
09-19-2020 03:12 PM
bradleyb
11-27-2015 07:50 PM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
dalehunter
09-25-2015 10:51 AM
jaiidutch
09-14-2015 10:29 AM
Quick Reply: Electronic Pointless Distributor
