fuel pump wont prime
Old 03-04-2010, 09:21 PM
AYEOH5.0
AYEOH5.0's Avatar
Default fuel pump wont prime
drove the car almost a 100 miles on monday, then drove it home and parked it. i drove my truck until today, but i had a job interview at a ford dealership and wanted to take my mustang to show them i am capable of working on automobiles and i tried starting it and it wont start. so i checked the fuel pressure and its at zero. i tried to start it again and noticed i dont hear the fuel pump prime. the car has literally not moved since the last time i drove it.
what could it be?
AYEOH5.0 is offline
Old 03-04-2010, 09:40 PM
AdderMk2
AdderMk2's Avatar
check the FP relay, see if it clicks, check the inertia switch... I like hitting peoples tail lights to trip them.
and if those get you no where, unplug your ECM, it should kick on instantly
AdderMk2 is offline
Old 03-04-2010, 10:52 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
go back to the fp plug behind the bumper and prob the power wire with a test light while someone pulses the key on , if it briefly lights the test light and ground is good, = safe to say pump went south
mjr46 is offline
Old 03-04-2010, 10:56 PM
AYEOH5.0
AYEOH5.0's Avatar
why would the pump all of a sudden go bad? and i checked the interia switch, that was the first thing i checked. how can i check the relay? i know where it is i just dont know how to test it.
AYEOH5.0 is offline
Old 03-04-2010, 11:01 PM
mjr46
mjr46's Avatar
they just do....happens many times, or what you can do, grab a rubber mallet and smack on the tank while someone cranks the car over, I've gotten many to start that way due to worn/faulty contacts in the pump windings, personally I like to work from the back to the front, if you go back to the pump harness and do the test I state and it powers up via lighting the test light up, no need to diagnose the fuel system any further as it's working properly and it's the load consumer that is bad = pump, the connector should be easily visible close to the back of the right side tank strap
mjr46 is offline
Old 03-04-2010, 11:09 PM
AYEOH5.0
AYEOH5.0's Avatar
ive actually already tried the mallet idea, guy at the ford dealership suggested it, o well if it is on its way out, time to get my 255 pump and run some boost!
AYEOH5.0 is offline
Old 03-04-2010, 11:13 PM
mjr46
mjr46's Avatar
WELL THEN CHECK FOR POWER BACK AT THE PUMP = 2 min job
mjr46 is offline
Old 03-04-2010, 11:17 PM
AYEOH5.0
AYEOH5.0's Avatar
i will in the morning. if im not getting a blip, what do i check next?
AYEOH5.0 is offline
Old 03-04-2010, 11:47 PM
ikeybmg
ikeybmg's Avatar
FP will go out instantly like that sometimes. Mine in my truck just did awhile back. Check the relays and inertia switch like has done ben said. Could be the crank sensor also. Don't forget to check it.
ikeybmg is offline
Old 03-04-2010, 11:48 PM
mjr46
mjr46's Avatar
the relay under the seat, there should be 12v to the relay coil and the ecm controls the ground for the relay windings to be pulled in via the pip signal, by pulsing the key if relay is working you should feel it click on then off after 2 sec in that short period if you here it click put the test light on the load carring wire that goes back to the pump coming out of the relay, if it clicks but doesn't transfer power across the contacts = bad relay you'll need a wiring diagram of the system to probe the proper wires
mjr46 is offline
Quick Reply: fuel pump wont prime
