How to: upgrade your 87-93 Mustang with new shift boots!
Old 03-22-2010, 06:53 AM
RedlineGoods.com
Former Sponsor
RedlineGoods.com's Avatar
Default How to: upgrade your 87-93 Mustang with new shift boots!
Hi everyone,
we were asked by the Admin to put together a write-up documenting the process of upgrading the boots and armrest on the Mustang.
First of all - why do it? Here's why, a sample pic from another car:
And, more specifically, on our cars:
So, now that the "why bother" is out of the way, let's get to the "how-to".
1. Disconnect the negative battery terminal. Work will be performed around the lighter socket which has constant power to it. Remove the armrest assembly. Locate and remove the mount access plugs on the console to expose the four bolts holding the armrest in place. (Gently pry them loose, do not break the clips holding them in.) Remove the four bolts holding the armrest in place (8mm socket required). Lift the armrest straight up to remove.
2. Remove the console shifter bezel. Grip inside of bezel and gently lift up to disengage the clips. Remove original shift boot from retainer ring and interior trim bezel - remove both staples and glue and clean the ring thoroughly. Remove the shift ****. The manual shift **** simply twists off. To remove the automatic one, look under the shifter handle (with a small mirror) there is a split ring, you have to get a small screw driver or allen wrench and press one of the tabs while pulling up on the handle with the button depressed.
3. Position the new boot lining up holes in the leather boot with trim ring holes. Use tape to hold the boot temporarily. For the automatic, the boot will simply wedge between the shifter plate and the bezel, so steps 3-5 are unnecessary. Just put the boot on, reinstall the bezel and reinstall the shifter handle.
4. Pierce leather with a piece of a stiff wire or a pin. Mount with either staples if you have a gun or by taking small measures of copper wire, slide them through the boot and the bezel and twist the ends together.
5. For additional hold, apply some epoxy-based glue or 270 automotive RTV silicone between boot and ring.Apply more between ring and bezel. Make sure you don't get it on the leather while sliding the boot into position.
6. Clamp the shift boot, ring and bezel together for 24hours so that the epoxy glue/silicone has time to try.
7. Remove the console top panel. Locate and remove the four screws (two front, two back) securing the console top panel to the main console body (Philips screw driver required). Engage the E-brake. Lift up on the console top panel; disconnect the lighter socket and the power mirror switch if so equipped. Your console top panel can now be removed.
9. Locate and remove rubber e-brake dust shield and plastic retainer. (Pull up on plastic retainer. These parts will most likely break, do not worry, they will not be reused.) Using a sharp razor blade cut what remains of all the plastic pegs (previously securing the rubber e-brake dust shield) flush with the console top panel.
Note: If alternate installation using factory mounting methods is desired, some have had luck heating the plastic pegs with a soldering iron (this will ruin your tip) to reshape them during removal and installation. Proceed at your own risk.
10. Prep upper console panel for e-brake boot installation. Lightly sand underside of console top panel (around e-brake opening) with 120-400 grit sand paper (this step is required to promote the Velcro's adhesion). Clean area with denatured alcohol. Cut and install 1/2" wide stripes of Velcro all around e-brake opening. (Hook side: Velcro brand industrial strength heavy duty adhesive).
11. Cut and install 1/2" wide stripes of Velcro to the e-brake boot (Loop side: Velcro brand industrial strength heavy duty adhesive).
12. Install e-brake boot in upper console panel. Insert e-brake boot up through opening in upper console panel. Starting at one end center the seam and gentle roll boot around making sure the Velcro fastens securely; continue up both sides leaving the end opposite the starting point for last. You are now ready to install the upper console panel complete with boot back into your car.
13. Reinstall upper console panel and armrest. (reverse order of removing them).
And now what we know why bother, how to do this, you probably want to know how much?
Please take the time to visit our sponsor ad!
https://mustangforums.com/forum/vend...g-87-93-a.html
What you'll find there are:
- pricing information (please do not ask about pricing in this thread)
- color and special finishing options (LOTS OF PICTURES)
Take care
Maciek
RedlineGoods.com is offline
Old 03-22-2010, 07:03 AM
RedlineGoods.com
Former Sponsor
Two new pics we've received recently:
Here's the new discount code: 7WPW02D478P - Valid through Friday, March 26th! This will give you 10% off on shift boots and other leather accessories from RedlineGoods.
Have a great weekend,
Maciek
Old 03-22-2010, 09:20 AM
Demon 340
Administrator
Demon 340's Avatar
members...this vendor is permitted to post in tech sections so long as they provide technical information. to some of you, installing a new shift boot might seem like a piece of cake job but to someone who has never done it (like a 16yo kid with a new fox body) a DIY of how to install it would be helpful. notice, he doesnt list prices...he just explains the DIY and mentions that he sells them.
remember, if you dont have anything nice to say...dont say anything at all. if you dont need to be shown how to change your shift boot just move on and dont trash up the thread for people who might need it.
thank you.
Demon 340 is offline
Old 03-22-2010, 07:02 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
the e-brake thing seems like a good idea since you cant get the rubber oem pieces just seperate without purchasing a new console
mjr46 is offline
Old 04-09-2010, 01:01 PM
RedlineGoods.com
Former Sponsor
Hi,
quadruple yellow thread on a New Beetle:
Here's the new discount code: C703N24IY8S - Valid through Friday, April 16th!
Have a great weekend everyone
Maciek
Old 04-09-2010, 06:07 PM
Doomstein
Doomstein's Avatar
I kinda want an e-brake boot now. Snap!
Doomstein is offline
Old 04-09-2010, 07:48 PM
86 5.0L
86 5.0L's Avatar
any love for an '86?
86 5.0L is offline
Old 04-09-2010, 07:52 PM
mjr46
mjr46's Avatar
Originally Posted by RedlineGoods.com
Hi,
Maciek
nice, try posting a mustang specific one, that would give me a better idea if it's what I'd like
mjr46 is offline
Old 04-10-2010, 02:36 PM
RedlineGoods.com
Former Sponsor
Oh yes! Just read this: http://www.redlinegoods.com/notsupported2.shtm
Take care
Maciek
Old 04-10-2010, 02:37 PM
RedlineGoods.com
Former Sponsor
Hi,
I'd really love to, but we can only post what we have at our disposal and as far as 86-93 Mustangs are concerned, there's not much to choose from, but here you go:
http://www.redlinegoods.com/Mustang8793shiftboot.shtm
Take care
Maciek
Quick Reply: How to: upgrade your 87-93 Mustang with new shift boots!
