1991 Mustang LX 5.0 - Which 347 Stroker kit should I go with?
Old 03-29-2010, 08:35 AM
filmnews
filmnews's Avatar
Default 1991 Mustang LX 5.0 - Which 347 Stroker kit should I go with?
I have a automatic 1991 Mustang LX. I am looking to go with a 347 stroker kit. Which kit is the best for the money? I have seen several from $800 to $1,200. What kind of HP gain can I expect?
filmnews is offline
Old 03-29-2010, 08:43 AM
NYMustang50
NYMustang50's Avatar
What are your goals.. You have to also figure in cam and heads and all other supporting mods to consider HP... I've seen some 347's make 350 rwhp and Ive seen 306's built right and make 400 rwhp.. Its all about the combo of parts you use. If I were to build a 347 I would want at least 450rwhp anything less I would be tearing it apart and doing it again..
NYMustang50 is offline
Old 03-29-2010, 08:49 AM
filmnews
filmnews's Avatar
The car currently has has a trick flow upper intake and a E303 cam. I am looking to add the 347 stroker and then run nitrous or a supercharger down the road. Looking for 500 whp or so.
filmnews is offline
Old 03-29-2010, 08:56 AM
NYMustang50
Well the cams to small for a 347 and if you want 500rwhp by doing a 347 and nitrous or supercharger your going to need a better block than stock.. So your going to need a dart iron or the ford boss block. Your looking at a minimum of 1200 just for the block. If I were you.. I'd give http://fordstrokers.com/ a call and have a in depth conversation with woody.
Old 03-29-2010, 08:59 AM
filmnews
filmnews's Avatar
Thanks for the heads up. I will give the a call. What would be the best setup for what I have now? 331 kit? I would like to keep the money down as much as possible and get good hp with what I currently have.
filmnews is offline
Old 03-29-2010, 09:05 AM
NYMustang50
What do you have done to the car? I can help you out if you tell me whats already done to it and I can help you get the most out of the car with out tearing down the block.
Old 03-29-2010, 09:16 AM
filmnews
filmnews's Avatar
I appreciate the help on this. It has a K&N intake, Accufab Throttle Body, Trick Flow Upper Intake, E303 Cam, BBK Shorty's,Off Road X-pipe and turn downs. It is a automatic and it currently has stock gears. I am thinking about going with 3.73 gears.
filmnews is offline
Old 03-29-2010, 02:05 PM
NYMustang50
For the automatic I'd go 4.11's thats my opinion on that. I would look into getting some gt40 aka explorer heads. Put some 1.7 rocker arms and get a shift kit and maybe TQ for that AOD.. Get some under drive pulleys and a electric fan. Then spray it if you find your self you want more. I'd run a 100 shot on that.. Thats my take if you want to go the cheap way instead of going through the motor and putting together a 5k dollar motor.
Old 03-29-2010, 02:27 PM
stanks347
stanks347's Avatar
You don't have to have a Dart or Boss block. It would be nice but if you go with a stud and valley girdle you can probly get away with it. I bought my rot. asem. from AD performance in Wash. ST. and I got a SCAT forged set up for $1400.
stanks347 is offline
Old 03-29-2010, 06:22 PM
minnow81469
minnow81469's Avatar
you could save up and get a short block that was already built from a reputable company for 2200 but if your looking for some bolt on gains get a set of heads like the gt40p or trickflow heads
minnow81469 is offline
NorthAmericanTuning
03-18-2016 11:21 AM
MusBBad95
08-17-2015 09:39 PM
MtnMustang
08-16-2015 08:07 PM
Soldier GT
08-12-2015 03:46 PM
daytooday
08-11-2015 09:22 AM
Quick Reply: 1991 Mustang LX 5.0 - Which 347 Stroker kit should I go with?
