Stud Mount Conversion Kits
Old 12-04-2012, 05:26 PM
  #31
FLcracker9
FLcracker9's Avatar
What mjr46 said. Trash the factory TFS springs, and get the correct springs/seats/keepers for your cam. This should help cure your valve float problem. Boy it's been a long time since I posted here!
FLcracker9 is offline
Old 12-04-2012, 09:03 PM
  #32
MonsterBilly
MonsterBilly's Avatar
is it okay to have them changed on the car or do i need to remove the heads.
MonsterBilly is offline
Old 12-04-2012, 09:06 PM
  #33
MonsterBilly
i have the springs that came with my cam but they are on another set of heads, the stock heads that i worked over before i decided that i needed new heads. can they be taken off and installed onto my trickflow heads with the heads still on the car?
Old 12-05-2012, 05:09 PM
  #34
FLcracker9
FLcracker9's Avatar
Is it possible, yes (using compressed air, or a piece of rope pushed into the spark plug hole. Is it the correct way to do it, no. Depending on the springs, the spring seats may need to be machined/shimmed, and once installed, install height, coil bind, seat pressure, open height, open pressure ect... needs to be verified for each valve. Others may disagree?
Old 12-05-2012, 06:33 PM
  #35
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
this^^^^^^^^^
mjr46 is offline
Old 12-05-2012, 08:26 PM
  #36
MonsterBilly
well alright. Ill just deal with it until i feel the desire to rip it apart again.
jwog666
12-27-2021 08:09 PM
baddog671
07-26-2016 01:20 PM
UrS4
10-03-2015 06:23 AM
Explosive
10-02-2015 07:45 AM
Quick Reply: Stud Mount Conversion Kits
