Stud Mount Conversion Kits
Old 04-05-2010, 06:27 PM
smbikes
smbikes's Avatar
Default Stud Mount Conversion Kits
I orderd a set of COMP Cams Magnum Rocker Arms that are stud mount and didnt know that my gt40 head were Pedestal mount! Has any one used them with the Crane Cams pedestal to stud mount Conversion Kits with the comp cams magnum rocker arms ?
smbikes is offline
Old 04-05-2010, 06:59 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
just send them back and order pedastal mount, using conversion kits are weak as the base still is a 5/16 size diameter
mjr46 is offline
Old 04-05-2010, 07:34 PM
minnow81469
minnow81469's Avatar
im assuming you got the p heads like me trust me not worth the hassle send them back and get the pedestal mount they arent as strong using the stud mount rockers i did the same thing and ended up buying heads twice lol
minnow81469 is offline
Old 04-05-2010, 08:28 PM
smbikes
smbikes's Avatar
Well it may be to late to send them back and they are not p's. The motor is going in my 77 f100 and wont really be pushed all that hard. What brand of Pedestal roller rockers do yall like? They all seem high $$
smbikes is offline
Old 04-06-2010, 04:41 AM
smbikes
smbikes's Avatar
Minnow, what happen with the conversion kit when you used it?
smbikes is offline
Old 04-06-2010, 02:14 PM
motorman524
MF Informant
motorman524's Avatar
If you aren't going to push it hard then why bother? I use Ford racing pedestal mount rockers and they work very well.
motorman524 is offline
Old 04-06-2010, 04:50 PM
minnow81469
Lol i broke a stud because they are weak they are small studs although it was my fault because i missed a shift at the track it was my first year of racing
Old 04-07-2010, 06:06 PM
smbikes
smbikes's Avatar
Motorman524 , i would use pedestal mount rockers but i have money tide up in these brand new Magnum Rocker Armsand cant get my money back so i need to use them . minnow81469 . what type of rocker did you use with the kit??
smbikes is offline
Old 04-07-2010, 06:19 PM
minnow81469
trickflow i mean you can do it why not reuse the stock ones you have anyways the ones off the e7te heads work same 1.6 ratio you dont gain from using the stud mount rockers you gain from the ratio and by the way when u get stud mount rockers you need an intake spacer and the tall valve covers
Old 04-07-2010, 06:22 PM
minnow81469
and you possibly might need new pushrods too
Quick Reply: Stud Mount Conversion Kits
