Sponsored by: DashLynx
downshifting
Old 04-15-2010, 12:49 PM
luis05gt
luis05gt's Avatar
Default downshifting
well most of the time i only downshift at a stop but today my buddy wanted to run them from a roll so i tried downshifting into 1st going 15 mph and it didn't want to go in it just grinded like there something wrong with the synchro could it be something is wrong or is 15 mph too fast to drop it in
luis05gt is offline
Old 04-15-2010, 09:28 PM
Jfsram
Jfsram's Avatar
Hard to say if 15 is too fast. Depends on the car. Some cars will slip into a lower gear at a pretty high speed. I drove a Passat turbo 6 speed. It seemed to be able to engage any gear at any speed.
Some cars will not. Generally steep geared cars and cars with big clutches. Big clutch means heavy disc. So the synchronizer is forcing the disc to ramp up to speed and it doesn't feel like ramping up.
Try throwing a few revs in and see if it goes in.
Jfsram is offline
Old 04-15-2010, 09:38 PM
MU71L4710N
MU71L4710N's Avatar
first gear with stock gears is good to like 30 or 35 i forget what, 15 is by no means too fast for it. when i downshift to first i give it a good rev to just about redline and it goes in fine. it will have trouble going in if you don't rev it high enough though.
MU71L4710N is offline
Old 04-15-2010, 09:55 PM
luis05gt
luis05gt's Avatar
so do you think my syncrho is broke it used to go in at 20 before i had it replaced or could it be anything with my clutch every other gear is fine
luis05gt is offline
Old 04-16-2010, 06:16 AM
a_penquin
a_penquin's Avatar
Mine wont do it, but I dont care its nice to know that if I screw up it wont let me.
a_penquin is offline
Old 04-16-2010, 04:07 PM
sv650lex
sv650lex's Avatar
Just try reving it a little. If everything else with the tranny is working fine don't worry about it.
sv650lex is offline
Old 04-18-2010, 02:22 AM
67mustang302
67mustang302's Avatar
Downshifting can be hard, and trying to downshift into 1st can be very difficult on most transmissions because the ratio requires very rapid changes in gear cluster speed which the synchro can't compensate for fast enough. You either have to slowly downshift into first or learn to heel and toe and rev match going into first.
My TKO 600 will downshift into 1st, though it's a fair bit notchy and hard doing it, but I usually rev match when I downshift most of the time anyway, so that makes it easy.
67mustang302 is offline
Old 04-18-2010, 04:21 AM
Snakebite64
Snakebite64's Avatar
No problems here and no revving for me
Snakebite64 is offline
Old 04-19-2010, 04:05 PM
tdcalhoun89
tdcalhoun89's Avatar
I've never "downshifted' into 1st, I've always been under the impression you weren't suppose to put it down into 1st until you've stopped...
tdcalhoun89 is offline
Old 04-19-2010, 04:09 PM
conejo172
conejo172's Avatar
At least with the 2010 v6 manual transmission the book said never downshift into first when above 15mph, could do transmission damage!
conejo172 is offline
Quick Reply: downshifting
