AMP Gauge wiring????????
Old 04-16-2010, 12:05 PM
mortman
mortman's Avatar
Default AMP Gauge wiring????????
I have installed the Ron Francis wiring harness system in my 68 coupe. One thing the system does not address is the AMP Gauge, according to the diagrams I have, the two wires splice together and run to the positive side of the starter solenoid and to the alternator. Is this correct?
Thanks
mortman is offline
Old 04-16-2010, 12:55 PM
MBDiagMan
MBDiagMan's Avatar
I am not totally grasping what you are saying UNLESS they mean to connect these two wires together in the case of no Ammeter being used. An Ammeter must be in SERIES so these two wires, one from the starter solenoid which in practice is the hot side of the battery, to the alternator which is another hot, would provide the connection for charging current from the alternator to the battery. With the Ammeter in SERIES with this circuit, it is then transferring that current but measuring it as it goes.
An Ammeter is basically a short, so connecting it in series is what you want. If after it is in the circuit it reads backwards, you will need to reverse the leads on the Ammeter.
Hope this helps.
MBDiagMan is offline
Old 04-16-2010, 02:22 PM
mortman
mortman's Avatar
this is how the wiring diagram shows to wire it, Excuse the art work and spelling Just does not look right, so i looking for confirmation and advice.
mortman is offline
Old 04-16-2010, 07:49 PM
ic237
ic237's Avatar
[QUOTE=mortman;6947595]this is how the wiring diagram shows to wire it, Excuse the art work and spelling Just does not look right, so i looking for confirmation and advice.
Hi,
That is right but your drawing is wrong. The amp meter is working of the small voltage drop across all that wiring. The amp gauge isnt carrying all that current like you would think. Its really a voltmeter not an amp meter.
The more current going through the charging wire the higher the voltage drop. Thats why the charge wire is so small. You upgrade the wire and your amp meter will stop working.
ic237 is offline
Old 04-16-2010, 08:08 PM
MBDiagMan
MBDiagMan's Avatar
Yes, ANY Ammeter is nothing but a voltmeter across a very low, high wattage fixed resistance. Usually something like .1 Ohms. I understand what you're saying then and the drawing with the yellow wire being the resistor makes total sense. Does it make sense to you mortman?
Old 04-16-2010, 08:18 PM
mortman
mortman's Avatar
Got ya, makes perfect sense. Thanks for the help,
Off to the wires........
mortman is offline
Old 04-16-2010, 08:22 PM
ic237
ic237's Avatar
I was scratching my head for a day with this one. But the trick was looking at the gauge. It shows the coil not the resistor.
ic237 is offline
Old 04-16-2010, 10:17 PM
mortman
mortman's Avatar
and the field wire off the alternator to the voltage regulator, in the diagram that one wire is missing? what happens if i wire wrong? i dont want to go kaboom.
Thanks for the help
mortman is offline
Old 04-16-2010, 10:35 PM
JMD
JMD's Avatar
Ron Francis wont send wiring for an amp gauge unless you specifically ask, but, I THINK if you run the big wire from the RON FRANCIS panel to the battery/+side of the solenoid THROUGH the shunt in your AMP GAUGE it may work.
I would call Ron Francis and ask a tech to be sure, it is free....
JMD is offline
Old 04-16-2010, 10:40 PM
mortman
mortman's Avatar
Thanks JMD, i did about a year ago never got a response....ill do that before i continue
mortman is offline
jwog666
12-27-2021 08:09 PM
Urambo Tauro
10-05-2015 09:37 PM
Matt's 95 Stang
10-05-2015 07:16 AM
Dathan
10-05-2015 05:52 AM
breaking
10-02-2015 01:27 PM
Quick Reply: AMP Gauge wiring????????
