2007 GT LAG IN THROTTLE RESPONSE
Old 04-19-2010, 10:16 PM
whiskeymt
whiskeymt's Avatar
Default 2007 GT LAG IN THROTTLE RESPONSE
Does anyone know what causes no response from idle to 1200rpm? No matter how slow I push on the pedal it jumps? In gear or out it doesn't matter. It seems like the pedal will move 1/2 inch before anything happens?
Thanks,
whiskeymt is offline
Old 04-19-2010, 10:34 PM
HypromanGT
HypromanGT's Avatar
Thanks,
So I'm not exactly sure what you're asking because your post is a little confusing, but:
1. It is possible that you do have "dead space" at the beginning of the pedal travel. There are a few things you can do to fix it. I ended up following some advice on the forums and removing the throttle pedal assembly, unscrewing the torx screws that hold the little cover on the electronic bits, and shifting the cover as far over as possible (the screw holes are oval so there is some room for adjustment). Put everything back together and the dead space is gone! You can search around here for the other solutions.
2. There can be lag in the Drive By Wire system. You could try the throttle recalibration procedure (again, search), but pretty much the only real "fix" is an aftermarket tune; Ford's tune just lags a lot...
EDIT: Got bored and decided to go find posts for you:
The mod to remove the dead spot: https://mustangforums.com/forum/2005...-must-see.html
This is the method I chose (not as scary as bending wires): https://mustangforums.com/forum/4308949-post453.html
Throttle recalibration instructions: https://mustangforums.com/forum/6197596-post9.html
Hope that helps!
HypromanGT is offline
Old 04-19-2010, 10:45 PM
whiskeymt
whiskeymt's Avatar
That helps some with the pedal lag.... I will try it.
The other problem would still be there. The rpm's should ramp up smooth, not jump from 800 to 1200. Once its over 1200 its very smooth.
Is this a computer problem the dealer has to program?
Old 04-20-2010, 07:08 AM
Nuke
Nuke's Avatar
Try the recalibration as mentioned above but a good custom tune will resolve that and then some.
Nuke is offline
Old 05-11-2010, 01:10 AM
cvLegend2be
cvLegend2be's Avatar
this has actually started happening with me. Im gonna try what HypromanGT said to do and see if it helps.
cvLegend2be is offline
Old 05-11-2010, 10:45 AM
replica
replica's Avatar
Mine did this stock and the "recalibration" didn't do anything. But that SCT tune sure did!
replica is offline
Old 05-12-2010, 12:51 AM
Simon1
Simon1's Avatar
Thanks,
What mods have you done to the car?
Simon1 is offline
CS2007
06-25-2019 09:45 PM
UrS4
10-03-2015 06:23 AM
guitarman376
09-30-2015 05:54 PM
FivePointToTheOh
09-29-2015 12:53 PM
CS2007
Florida Regional Chapter
09-29-2015 12:06 PM
Quick Reply: 2007 GT LAG IN THROTTLE RESPONSE
