Transmission : Hard to put it in Reverse
Old 06-16-2010, 09:40 PM
GTVAPSAMTIK
GTVAPSAMTIK's Avatar
Default Transmission : Hard to put it in Reverse
I have 01 GT with 46K miles on it. Its manual and whenever I try to put my car in Reverse, most of the time I just have to struggle and wont go in Reverse. I have to make 2 or 3 attempts to put it in reverse. But sometimes its really smooth.
Manual transmission oil was changed with Mobile 1 Syn at 43k Miles.
GTVAPSAMTIK is offline
Old 06-17-2010, 12:20 AM
Shotgun Love
Shotgun Love's Avatar
sounds normal to me
Shotgun Love is offline
Old 06-17-2010, 12:57 AM
0949er
0949er's Avatar
thats how they all are bro.
A nice trick to know is if you let up on the clutch like not even a inch it will go into R like a warm knife through butter (don't engage yoru clutch though!! just take it a lil bit off the floor)
0949er is offline
Old 06-17-2010, 12:59 AM
35aniv stang
35aniv stang's Avatar
another trick is to put it in first then second and it will go in thats what i do
35aniv stang is offline
Old 06-17-2010, 01:51 AM
trailor
trailor's Avatar
yep. or just first, then reverse. either way its always been a PITA. just be lucky urs dont grind like a lot of em do
trailor is offline
Old 06-17-2010, 08:05 AM
K Z
K Z's Avatar
If I put mine straight into reverse it'll make a nice little clang with a slight grind feel. I either go 1-R or 5-R, and always in reverse when I park it I find that helps out some to.
K Z is offline
Old 06-17-2010, 08:25 AM
cliffyk
TECH SAVANT
cliffyk's Avatar
There is a TSB about this...
cliffyk is offline
Old 06-17-2010, 11:05 AM
Evenexchange
Evenexchange's Avatar
I find that 5-R works every time as far as anti-grinding goes.
Occasionally though, as far as the "blocking" issue goes, maybe 1 out of 30 times, the shifter will hit a "wall" trying to go into reverse, even after trying this 5th - reverse method. This is easily fixed by putting the car into neutral, taking your foot off the clutch and simply trying again. It should definitely go in after this second attempt.
Evenexchange is offline
Old 06-17-2010, 11:49 AM
devongarver
devongarver's Avatar
Coulda just put some purple ice in it...fix it right up...just sayin...
devongarver is offline
Old 06-17-2010, 11:58 AM
PurpleIcedGT
PurpleIcedGT's Avatar
Definitely try some purple ice...
PurpleIcedGT is offline
Quick Reply: Transmission : Hard to put it in Reverse
