Suspension/Steering Torque Specs....
Old 06-29-2010, 02:48 PM
pootypeters
pootypeters's Avatar
Default Suspension/Steering Torque Specs....
Does someone with a GOOD service manual have the torque specs for the following list of connections on a 1966 Mustang Coupe - 289 4V. My Chilton's is pretty much worthless in this area.
- Lower Control Arm to Frame?
- Upper Ball Joint to Spindle?
- Lower Ball Joint to Spindle?
- Pitman Arm to Steering Box?
- Outer Tie Rod End to Spindle?
- Inner Tie Rod End to Center Link?
- Center Link to Pitman Arm?
- Idler Arm to Center Link?
Thanks....
pootypeters is offline
Old 06-29-2010, 04:22 PM
67mustang302
67mustang302's Avatar
LCA will depend on whether you have an eccentric eliminator(mine is 50lb-ft iirc) or it's the stock eccentric. Upper and lower ball joints are around 40lb-ft iirc, pitman arm to steering box is something like 150-200lb-ft(for the 1-1/8 shaft, your's may be smaller, yeah, a lot) Tie rod ends are like 30lb-ft iirc...which would be about the same for the connections to the link.
Do yourself a favor though and buy a decent manual that has torque specs in it. Barring though you can get an engineers cheat sheet that lists torque specs based on size and thread pitch of connectors.
67mustang302 is offline
Old 06-29-2010, 09:34 PM
pootypeters
Awesome! Thanks for the help. Yeah, I definitely need a complete service manual. Any suggestions?
Old 06-30-2010, 08:45 AM
gjz30075
gjz30075's Avatar
Definitely factory Ford. Like this:
http://www.mustangsunlimited.com/itemdy00.asp?T1=SM2+01
gjz30075 is offline
Old 06-30-2010, 10:46 AM
kalli
kalli's Avatar
ya, get the Ford shop manual. you will need that. either book or cd, whatever you prefer
kalli is offline
Old 06-30-2010, 12:57 PM
pootypeters
I'll be sure to get that manual. Thanks.
mtgldr
02-03-2024 09:00 PM
guitarman376
09-30-2015 05:54 PM
wraith777
09-28-2015 10:49 AM
LivingInThePast
09-16-2015 12:20 PM
spamedic
09-09-2015 12:15 AM
Quick Reply: Suspension/Steering Torque Specs....
