Old 10-22-2015, 05:47 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Ford Mustang Interior Guides
Print Wikipost
Quick help window motor removal
Old 07-04-2010, 02:51 PM
sharpshooter33
sharpshooter33's Avatar
Default Quick help window motor removal
Does the entire glass and regulator have to be removed to replace the window motor???
Anybody have a link to tech procedure?
I'm right in the middle of pealing the door apart and don't have access to Internet other than my iPhone!
Thx
SS33
sharpshooter33 is offline
Old 07-05-2010, 11:15 AM
945LSTANG
945LSTANG's Avatar
first of all make sure the window is rolled up otherwise you won't be able to get it out of the hole in the door IIRC. all you have to do is disconnect the connector to the motor and remove three or so bolts and the motor can come out through the larger hole towards the front of the door. there might even be a few rivets that you have to drill out, but thats not always the case.
you shouldn't have to remove anything extra to get the motor out.
945LSTANG is offline
Old 07-06-2010, 01:26 AM
sharpshooter33
Default get'er done!
Yup. It comes out by it's self. The OEM is a bitch to get out, had to loosen the Regulator bolts and it took some twisting and turning but it came out. The aftermarket was thinner and just slid right in. Works great!
Now I can at least roll down the window in the 90degree weather we've been having. Until the A/C really kicks in
Thanks
SS33
Old 06-17-2011, 04:11 AM
DavidSoto
DavidSoto's Avatar
Default Power Window Motor Installation
Just a share... I found this power window motor installation guide very useful, the process are so easy to follow. Hope this helps.
Window Motor Installation Guide :http://www.delorean.com/pdf/window.pdf
DavidSoto is offline
Granatelli Sales
01-20-2020 12:34 AM
SSRFUZZY
Members Other Vehicles
01-06-2016 08:22 PM
Pyrate Dave
09-10-2015 07:30 PM
Mustangmalo
09-06-2015 05:22 PM
Quick Reply: Quick help window motor removal
