Oil and Oil Related Topics A place to post your oil related questions and comments
First time changing Mach 1's oil and oil filter myself. Lots of Questions.
Old 07-05-2010, 07:47 PM
RickyD53
RickyD53's Avatar
Default First time changing Mach 1's oil and oil filter myself. Lots of Questions.
I've had my 04 Mach 1 for about a month now and wanted to change the oil myself. Im unsure of what type of oil to use and what type of oil filter to use. I want to use the best stuff for my car to make her last longer. any help is appreciated.
I've heard that 5w-20 is the weight, but which synthetic oil is better? Mobil 1, Motorcraft, Quaker state, Pennzoil? And what oil filter is the best to be used.
RickyD53 is offline
Old 07-05-2010, 07:58 PM
Unleashedbeast
Unleashedbeast's Avatar
If you are truly concerned to buy the best, look no further than AMSOIL.
I would recommend the SSO 0W-30 (better than the 0W-20 and 5W-20 - and only slightly thicker) and EaO11 oil filter.
Engine Oil
Grade 1......API*
100% Synthetic 0W-20 Motor Oil (ASMQT)
XL 5W-20 Synthetic Motor Oil (XLMQT)
Signature Series 0W-30 100% Synthetic Motor Oil (SSOQT)
All TEMPS......5W-20
Those are what AMSOIL recommends, but the SSO 0W-30 is their BEST oil, and what I personally use in my 4.6L
You can even run their oil all year long with only one oil change up to 25,000 miles.
Unleashedbeast is offline
Old 07-06-2010, 11:55 AM
99GTvert
is my username.
99GTvert's Avatar
Engine Oil
Grade 1......API*
What makes AMSOIL the best?
99GTvert is offline
Old 07-06-2010, 01:54 PM
Unleashedbeast
Read this link to get the idea of formulation differences
http://www.driven2modify.com/showthread.php?t=25162
Read this link to see what is means in real world testing
https://www.amsoil.com/lit/g1971.pdf
Old 07-06-2010, 03:30 PM
ShadyNinja
ShadyNinja's Avatar
Nice 1st post
welcome to the forum.
ShadyNinja is offline
Old 07-08-2010, 08:02 PM
rygi23
rygi23's Avatar
+1 on the Amsoil. If that breaks your bank, as it does mine, go with whichever reputable pure synthetic is on sale and a motorcraft filter. I go with the 5w20 which ford says to use. And I'll apologize for the guys in the Mach section being terds. Welcome to the Mach family.
rygi23 is offline
Old 07-09-2010, 09:40 AM
lizzyfan
Underboss
lizzyfan's Avatar
You cannot beat Motorcraft semi-synth (12.00 for 5 quarts a Wallyworld, you need 6 qts) and a Motorcraft filter
lizzyfan is offline
Old 07-09-2010, 09:41 AM
lizzyfan
Underboss
lizzyfan's Avatar
Originally Posted by ShadyNinja
Nice 1st post
Better look again, he's been a member for over 4 years
lizzyfan is offline
Old 07-28-2010, 04:26 PM
SCCAGT
SCCAGT's Avatar
Actually it can be beat.
Although, for the money, its a damn good value for what you get. I'm not knocking it.
Now, like most products, you get what you pay for. If you want the "***** best", Amsoil is the way to go.
As far as going with "cheaper synthetics", understand that you are NOY buying a synthetic oil. It has been discussed to no end on every car forum. Pennzoil, Quaker State, Valvoline, Castrol (the instigator of all this fake stuff), etc, are regular oils further formulated to mimic a synthetic in its new condition. As these fakes get used, they break down and lose all their "synthetic" attributes the same way as non-synthetic-labeled dino oils.
For information on this extra refining process, you can wiki "hydrocracking". It's a process used for many products, including motor oils.
SCCAGT is offline
Old 07-28-2010, 06:41 PM
ShadyNinja
ShadyNinja's Avatar
oops
my mistake
Vehicle: 1
some how I glanced at that and thought it was post count.
well then....
great 7850th post
the last few posts might start to explain it....
Quick Reply: First time changing Mach 1's oil and oil filter myself. Lots of Questions.
