5.0 explorer plenum on 5.0 mustang??
Old 07-23-2010, 10:11 PM
8850stang
8850stang's Avatar
Post 5.0 explorer plenum on 5.0 mustang??
bought mustang from guy and turns out that the plenum and throtle body on it is from a 5.0 explorer. it is the plenum with the curved neck for the throtle body. well i was wondering if this could make it jumpy at low idle and cause it to idle high. i have the screw in the throtle all the way out and the star screw (that has something to do with the idle air valve) is barely turned out. does this plenum give it more horse power and could it be why its so touchy and hard to set idle?
8850stang is offline
Old 07-23-2010, 11:25 PM
enix187
enix187's Avatar
check your timing, could explain the idle, yes the explorer intake is better than the stock 5.0 intake, its an improved version of the gt40, as far as power increase, I wouldn't think it'd be much, but it is a better intake, start looking at other things for the idle
enix187 is offline
Old 07-24-2010, 06:12 AM
nitrous_bob
nitrous_bob's Avatar
idle problems are usually vacuum related.
start looking at the hard plastic lines, and near the distributor the tube from the intake to the box in the fender
if you unplug the IAC and the car stalls..... you have issues that you need to fix.
also unplug the battery for about 20 minutes when you make changes. the computer will adjust stuff to make it run, and you dont want that
go read here....very good drivability thread, this guy knows his $h!t, hope you have a minute...lol
http://www.stangnet.com/mustang-foru...checklist.html
nitrous_bob is offline
Old 07-24-2010, 06:28 PM
8850stang
8850stang's Avatar
so when i unplug the idle air valve it should just die like i cut the switch off? and does anyone know how the set the star screw, under the little cap, that has something to do with the idle air valve?? i thought i had everything kinda close but sense i read all that now idk. im glad theres someone smart in this world to help me!!!!!
Old 07-24-2010, 11:12 PM
enix187
enix187's Avatar
read the information in the link man, it will help you sort out the problem, and no, it shouldn't die when you unplug the idle air
enix187 is offline
Old 07-25-2010, 09:41 AM
AdderMk2
AdderMk2's Avatar
id like to see pics of your engine
AdderMk2 is offline
Old 07-25-2010, 02:17 PM
8850stang
8850stang's Avatar
why did u want to see pix? im still working on getting the other guys rigging out of it.
Old 07-25-2010, 02:22 PM
8850stang
8850stang's Avatar
srry had problem the first time with pic. maybe this got it
Old 07-25-2010, 02:37 PM
8850stang
8850stang's Avatar
8850stang
8850stang's Avatar
finally dang!!!! srry guys but this is my first forum lol
Quick Reply: 5.0 explorer plenum on 5.0 mustang??
