Engine knocking or tapping noise
Old 07-31-2010, 08:50 PM
FLEX1025
FLEX1025's Avatar
Default Engine knocking or tapping noise
My 04 v6 stang has a bad knocking/tapping noise. I removed each spark plug wire one at a time and started it. None of them stopped the noise. It also has a Check Engine Light on. Im lost.
FLEX1025 is offline
Old 07-31-2010, 10:05 PM
FLEX1025
FLEX1025's Avatar
sounds kind of like this. http://www.youtube.com/watch?v=uoU9Sk9wtQ8
FLEX1025 is offline
Old 08-01-2010, 11:56 PM
pennywise88
pennywise88's Avatar
Do you have access to an OBD scanner? If there's a check engine light a good place to start would be to figure out what code it's spitting out to trigger the CEL. Unless of course the CEL is a result of having your spark plug wires unplugged, but I'm assuming that's not the case since you bothered to mention it.
pennywise88 is offline
Old 08-02-2010, 07:22 AM
astentine
astentine's Avatar
May be a dumb response, but I don't know what you know about cars, so I'll say it. When I had my first car, I had an annoying ticking like that as well. It never went away and it got faster as the engine reved. I had about 1 out of 5 quarts of oil in my engine...
Check your oil. If the sound is exactly like that sound in the video and gets faster with acceleration, then oil is at least a good place to start
astentine is offline
Old 08-03-2010, 03:55 PM
Brian68
Brian68's Avatar
My two cents.... I had a ticking/knocking issue with my 2000 that I couldn't figure out. I had everything checked out changing the oil and everything with no results. Finally I took it to a friend and we figured out it was a cracked weld in the exhaust manifold. It was so small that when the engine was cold it would allow the exhaust to pass which made the ticking sound. As the engine warmed up the manifold expanded and it went away leading me to believe it was an oil/lifter issue. I had the manifold welded and reinstalled and it runs great now. This might not be your problem, but it's worth a mention just in case. Good Luck!
Brian
Brian68 is offline
Old 08-08-2010, 02:43 AM
shutupsocks
shutupsocks's Avatar
Question
Brian
how much did you pay to have that done?
shutupsocks is offline
Old 08-09-2010, 10:27 AM
FLEX1025
FLEX1025's Avatar
This is my car.
http://www.youtube.com/watch?v=0qPouE8pV0E
http://www.youtube.com/watch?v=2T1vCbzPcFc
FLEX1025 is offline
Old 08-09-2010, 10:32 AM
03shadow
03shadow's Avatar
oh man that doesnt sound good at all, you definitely need to find out what your check engine light is all about. it could be a good hint as to what it is
03shadow is offline
Old 08-09-2010, 10:45 AM
FLEX1025
FLEX1025's Avatar
I have to try to find a scanner to use. Any clue to what it sounds like? could it be the oil pump?
FLEX1025 is offline
Old 08-09-2010, 12:00 PM
03shadow
03shadow's Avatar
my experience with problems with cars is pretty limited, i couldnt tell ya what it is. im sure someone around here can give a few guesses though
03shadow is offline
Quick Reply: Engine knocking or tapping noise
