Stereo Wiring diagram
Old 09-22-2010, 01:54 PM
TheEvilBain_TDB
TheEvilBain_TDB's Avatar
Default Stereo Wiring diagram
Ok Ive been looking for the wiring diagram to my 2002 mustang Gt Convertible. It had the mach 460 setup. Who ever owned the car before cut the wires. I would like to run the factory amps I see 2 of them next to the convertible top motor but I dont see were one would have been right under the headunit (is there 3 amps or just the 2?) All the wiring digrams I see dont say anything about the amp wiring colors only speakers,power and ground.
TheEvilBain_TDB is offline
Old 09-22-2010, 06:36 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
Here it is...
cliffyk is offline
Old 10-07-2011, 10:56 PM
Brian68
Brian68's Avatar
Exactly what I was looking for! Thanks CliffyK!
I made my weekly trip to Pic-A-Part and found a fresh Mustang that had just been delivered. Long story short I grabbed a few parts I needed and the entire Mach 460 system. Head unit (all plugs with aprox 12" of wire for splicing), both pillar speakers, both door speakers, entire rear unit with all speakers amps ect (with plenty of wire) and rear dash cover with the Mach raised grill. The car still had all it's windows so it hadn't been rained on or exposed to the eliments. Entire Mach system cost me $50. I compared this diagram to the wires on the system and I was able to account for everyone with the exception of two wires that say "ends in harness" and one that goes to "vehicle speed control". I'm going to see if I can make this work in my 2000. Keep your fingers crossed. I can't thank everyone on this forum (and the search button) enough for all their help.
B
Brian68 is offline
Old 10-08-2011, 07:33 PM
smashten
smashten's Avatar
How do you get the covers off the tweeters by the side view mirrors? I tried pulling but it seemed like the fabric was going to give. Are there specific spots that I should squeeze?
smashten is offline
Old 10-08-2011, 07:54 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
Just pull them off, they are help by several shallow interlocking bevels cast into the speaker frame and cover--you'll see this when you get one off.
Prying at the vertical rear joint, outward, with your nails/finger tips seem to work best...
cliffyk is offline
Old 10-10-2011, 06:17 PM
Brian68
Brian68's Avatar
How do you bolt the speakers to the door frame? The screw/bolt lines up with a hole in the door frame but there's no threads behind it. I'm thinking about mounting a post in that hole with the mirror off then sliding the speaker over the post and putting a nut on it.
Brian68 is offline
Old 10-10-2011, 07:10 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
It uses a metric hex head sheet metal screw with a captive washer, the head is 7mm, it's 16 mm long. This is a bit bigger than a US #6 and a bit smaller than a #8, 5/8" long...
cliffyk is offline
Old 10-16-2011, 07:47 PM
smashten
smashten's Avatar
thanks cliff. I'll give it another shot.
smashten is offline
Old 08-07-2012, 10:00 PM
JUNKYARDBWC13
JUNKYARDBWC13's Avatar
Default what do i got
how do i tell what stereo system is in my 2002 mustang gt
JUNKYARDBWC13 is offline
Old 08-08-2012, 12:20 AM
JC316
JC316's Avatar
Damn thread necromancer. If it's the mach 460, you will have tweeters in the corners of your doors, where the mirrors are. They will say Mach on them.
JC316 is offline
jwog666
12-27-2021 08:09 PM
Urambo Tauro
10-05-2015 09:37 PM
Matt's 95 Stang
10-05-2015 07:16 AM
Dathan
10-05-2015 05:52 AM
jrrhd73must
10-02-2015 09:17 PM
Quick Reply: Stereo Wiring diagram
