Best stock ECU for 91 2.3/AT?
Old 09-29-2010, 05:47 PM
zonker
zonker's Avatar
Default Best stock ECU for 91 2.3/AT?
I've got a 91 mustang 2.3 with an automatic and it's a calif model.
Would a federal model or a different year ECU from another mustang (or ranger??) be a nice cheap upgrade?
I tend to believe the earliest year that accepts the DIS and AT from a federal model would be the moost aggressive in terms of stock fuel and timing maps.
your thoughts??
zonker is offline
Old 10-01-2010, 01:20 PM
sleeper_inc
sleeper_inc's Avatar
There is no better computer... sorry
sleeper_inc is offline
Old 10-04-2010, 07:30 PM
zonker
zonker's Avatar
How about the difference between the California and federal models? Typically the Federal ones are a little more liberal with ignition timing and egr control.
You don't think substituting out a CA ecu for a Fed ecu might help?
zonker is offline
Old 10-04-2010, 11:08 PM
sleeper_inc
They had the same computer after 1990 sooooo there would really be n gain what so ever, caly models have the same HP as the non caly models. Only they got MAF a year or two earlier
Old 10-05-2010, 01:27 AM
zonker
zonker's Avatar
naw - different computers.
91-93 2.3 A/T (Federal): F1ZF-12A650-BB (D1L1)
" " " " (Calif): F1ZF-12A650-DB (J1D1)
91-93 2.3 M/T (Federal): F1ZF-12A650-AB (C1A1)
" " " " (Calif): F1ZF-12A650-CB (...)
they BB and DB interchange as far as function goes, but they have different programs, and if I had to guess, the Federal models allow the car to run a little dirtier and get a little better hp and/or gas mileage.
On the 98-up Escort ZX2's this holds very true. Typically on that car, the older federal pcms produce more power and mileage even though Ford rates them as the "same".
zonker is offline
Old 10-08-2010, 08:11 PM
sleeper_inc
If you had the answer then why even ask the question? and test it out, let us know how it goes
Old 10-08-2010, 08:19 PM
zonker
zonker's Avatar
I don't want to re-invent the wheel if someone has already done this, and if someone had, then i wouldn't have to buy a second ecu for my car if it's not going to help.
so... if anyone out there has swapped ecu's from cali to federal (or some other box), let me know and save me the learning curve expense on this car.
zonker is offline
mungodrums
09-29-2015 09:18 PM
Meystang
09-25-2015 04:05 PM
ccdguy
09-19-2015 05:20 PM
rksnow1
09-14-2015 08:46 PM
angeljoelv
SVT Forums
09-10-2015 09:12 PM
Quick Reply: Best stock ECU for 91 2.3/AT?
