91 mustang 5.0 low rpm stumble...
Old 10-30-2010, 07:47 AM
Shorter7
Shorter7's Avatar
Default 91 mustang 5.0 low rpm stumble...
Ok i just rebuilt and installed a new motor in my mustang and when i hold it around 1500 rpm it starts to kinda stumble its not really a miss just like the timing or something is off then the check engine light comes on it does it for a few seconds then the check engine light goes off and the rpm jump up about 1000. If your driving it and it happens its like the car falls on its face and kinda kicks and bucks. I believe its a timing issue because i can take the timing diode thing out and it doesnt seam to do it and when you drive it with it out it seams like it is being sluggish just like when its acting up with the diode in and the check engine light on...I have replace every vaccum line on the car so I dont think its that i might try to starter fluid spray test later today but I would just like some ideas on what else this could be I have other distrubutors and icm's i might try to change them out also Thanks for any help anyone can provide me with.
Shorter7 is offline
Old 10-30-2010, 10:14 PM
Bubba 95SN
Bubba 95SN's Avatar
Gee, cel on...do the EEC1V tests and find the codes. Fix the codes, betcha the problem disappears all be itselfff.
Bubba 95SN is offline
ShaneB26154
35
03-04-2021 04:05 AM
msavoia23
12
07-07-2018 12:08 PM
Stangbass
08-22-2015 08:33 AM
Philhampton1
08-21-2015 12:04 PM
daytooday
08-11-2015 09:22 AM
Quick Reply: 91 mustang 5.0 low rpm stumble...
