Loss of Power
Old 11-04-2010, 09:20 PM
stang98sa
stang98sa's Avatar
Default Loss of Power
Recently my stock stang started gradually loosing power upon acceleration. I can have the gas peddle almost to the floor and it seems as though the engine takes forever to catch up. I have replaced plugs and gas filter and neither fixed problem. I thought it might be the catalytic converters. Any insight on my problem?
stang98sa is offline
Old 11-04-2010, 09:30 PM
Crazycarnut
Crazycarnut's Avatar
Is your engine revving with no power or is it not revving as well? stick or auto? The more info you can put out the better someone can help you.
Crazycarnut is offline
Old 11-04-2010, 09:39 PM
stang98sa
stang98sa's Avatar
engine seems it is reving with loss of power as well when parked. Car has automatic transmission.
Old 11-04-2010, 09:52 PM
MU71L4710N
MU71L4710N's Avatar
clogged cats can cause this, but USUALLY theres a CEL code being thrown. is your car popping codes? (service engine soon/check engine light)
my car just had a fuel pump go out. it would drive normally under half throttle, but if i tried to floor it the car would literally go limp and start bucking, then catch up a bit, then fall back on its face. could barely rev it in neutral either.
MU71L4710N is offline
Old 11-04-2010, 09:59 PM
stang98sa
stang98sa's Avatar
No service engine soon lights....no warnings on dash. It doesn't spit or sputter like a fuel issue. It is like going slow with your foot all the way down on the accelerator. Unresponsive.
baddog671
07-26-2016 01:20 PM
KingRando
10-02-2015 08:06 AM
ChampInSD
10-02-2015 04:55 AM
09-25-2015 06:58 PM
Quick Reply: Loss of Power
