1997 ford mustang gt 4.6 bad oil leak engine gone? *pics*
i've called around for this part "oil filter adapter" auto zone or any of the other auto stores don't got it.. seems i either gotta go with the dealer or the junkyard.. $50 from the junkyard and $180 from the dealership... i called around as well to see how much it would cost to get it installed.. and best i've came up with is $50-$60.. i may have a shop do it for me as i don't have the exact tools do it. from research i did the hole is there stock.. and it is there to let you know it's gone bad.. but if that's the case i think that is horrible.. if you are unaware it went bad and didn't catch the oil leak in your drive way or down the street.. your engine will be gone.
i dunno if i'm aloud to post links to other websites here but this is where i found more information about my issue
http://www.modularfords.com/forums/s...filter-adapter
it is the oil cooler. it comes on cobras. op is your 97 a cobra? that hole is supposed to be there it is a weep hole just like the water pump has. i would not go to a junyard and get one unless money is really tight. you will have to either go to a stealership or try your luck in the parts section on a few different forums. might be one on ebay too.
replace the adapter do not jb weld or anything else the best way is to just replace it. i would do a little bit more research to see what is going on if i were you, because ive never seen something like that bfor. its a perfect hole. its wierd.
Mine leaked like crazy at the same spot - it is a weep hole - and there is a Ford gasket and O-ring kit you can buy from the dealer to repair it. I had a guy who worked for a Ford dealer do it for me on the side and no leak since. Contact the dealer and they should be able to get the kit for you.
#20
NorthAmericanTuning
11-09-2016 11:45 AM
NorthAmericanTuning
03-18-2016 11:21 AM
08-10-2015 01:44 PM
