thinkin about converting Auto to Manual
i have built my entire car from the ground up, except for the tranny. i know i can do the conversion myself, however, i dont know exactly what all parts will be necessary for the swap. i have read a couple threads about it, but none are very clear about whats needed.
any input regarding parts (clutch, wiring?, torque conv, housing, what tranny, bla bla) would be great.
http://www.moddedmustangs.com/forums...-swap-how.html
parts needed:
interior:
shifter
manual pedal set
clutch cable, quadrant, firewall adjuster
manual shifter bezel
shifter base insulator
shifter handle
parts:
engine seperator plate
pilot bearing
clutch kit
flywheel
flywheel bolts
pressure plate bolts (10.5 and 11in kits are different size bolts)
trans
trans fluid
trans sensors (if not with trans, manual and auto trans sensors are different)
shift fork (if not with trans)
x-member if going t56
manual trans wiring harness
driveshaft (or change to a manual yoke)
things you will have to modify:
wire harness for trans (if you use stock auto main harness)
trans tunnel
tune/ecu swap
parts needed:
interior:
shifter
manual pedal set
shifter handle
parts:
pilot bearing
clutch kit
flywheel
flywheel bolts
trans
trans fluid
trans tunnel
tune/ecu swap
Amp Performance sells conversion kits for people how want to change
from automatic transmission to manual transmission check them out
they will probably be able to save you some money from purchasing
everything peice by peice.
www.ampperformance.com
mungodrums
Suspension
09-07-2015 07:22 PM
