Old 10-20-2015, 10:28 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Exterior
Print Wikipost
hood won't open
Old 11-17-2010, 07:23 PM
ghoul31
ghoul31's Avatar
Default hood won't open
I have a 95 v6 automatic.
I left my lights on and the battery died. But the hood release isn't working, so I cant open the hood.
Is there a way I can get this hood open so I can charge my battery?
thanks
ghoul31 is offline
Old 11-17-2010, 07:28 PM
a_penquin
a_penquin's Avatar
The releases are pretty stiff, try pulling harder. Only other way would be unbolting the hinge, or a pry bar followed by replacing whatever is damaged.
a_penquin is offline
Old 11-18-2010, 12:56 AM
NeoTokyo
NeoTokyo's Avatar
try to spray the hood latch with some WD-40, let it soak and then try to open it again, tug hard.
NeoTokyo is offline
Old 11-18-2010, 01:54 AM
MU71L4710N
MU71L4710N's Avatar
what happens when you pull on the hood release lever? does it pull all the way out freely? or does it just get very stiff? if it gets stiff all the sudden your just not pulling hard enough. if there is almost no effort required, the cable snapped somewhere. ive never had to deal with that situation, but if i did, i would jack the front of the car up and try to come up from under the car and manually release the hood somehow. wheather thats cutting the cable off near the latch and yanking on it, or unbolting it, or something. i'd have to look under my hood to see how i'd open it if the lever didnt work.
and WAY before i'd ever try to crowbar it up, i would just tow it to ford or somewhere i guarantee they could get the hood popped with much less damage done than prying the hood off.
MU71L4710N is offline
Old 11-18-2010, 04:09 AM
petrock
petrock's Avatar
If the cable did snap, check if you can see the cable going to the hood latch through the grill. If you can, try pulling on the cable to see if it releases the latch.
+1
Good luck, and report back how you got it open. Enquiring minds what to know...
petrock is offline
Old 11-18-2010, 04:48 AM
Daehawk
Daehawk's Avatar
Have someone push down on the hood at the latch area as you pull the release cable or vice versa.
Daehawk is offline
Old 11-19-2010, 12:30 PM
ghoul31
ghoul31's Avatar
ok, I got it open. It requires one person to pull the release while a second person pulls up on the hood. I can do it by myself now by reaching through the grill and moving the lever with a screwdriver and pulling the hood up at the same time.
ghoul31 is offline
Old 11-20-2010, 05:20 PM
petrock
petrock's Avatar
Sounds like you've got a hood alignment problem, or the hook in the hood that goes into the hood latch may be bent or offset or something like that. If its not fitting correctly, it can get jammed like this.
petrock is offline
BOB ROME
07-26-2023 01:54 PM
PaulH2
20
01-31-2016 09:48 AM
Urambo Tauro
10-05-2015 09:37 PM
ChampInSD
10-02-2015 04:55 AM
tj@steeda
Florida Regional Chapter
09-30-2015 08:04 PM
Quick Reply: hood won't open
