My odometer randomly stops working? =[
Old 11-23-2010, 02:42 PM
DigitalTrixx
DigitalTrixx's Avatar
Default My odometer randomly stops working? =[
Anyone know what might cause this? it's a 2000. I bought the car about 2 weeks ago and i am trying to figure out how many miles a tank of gas gets me, but it randomly shuts off on me and stops calculating my trip.
DigitalTrixx is offline
Old 11-23-2010, 06:22 PM
MustangSally94
MustangSally94's Avatar
the gears in the cluster are probably going bad. Pull the cluster out and check em out... if the teeth are good then if im not mistaken grease will fix it
MustangSally94 is offline
Old 11-23-2010, 06:23 PM
Fink
Fink's Avatar
99+ are digital, no gears.
Take the cluster out and see if there is a loose connection. I had this happen to my 99 a couple times but never really thought much of it.
Fink is offline
Old 11-23-2010, 06:58 PM
DigitalTrixx
Thanks. going to try this http://www.moddedmustangs.com/forums...-lighting.html soon... need to get a soldering iron from a friend tho =\. hope this is the problem.
Old 11-24-2010, 08:47 PM
SuPa StaLLiOn 7
SuPa StaLLiOn 7's Avatar
My trip odometer doesn't reset but my odometer usually flashes in and out from time to time... I usually hit the part where the odometer is and it flashes back on (yeah I have a cheap fix LOL) but I will read that link posted above... seems like it's a common issue.
SuPa StaLLiOn 7 is offline
Old 11-24-2010, 08:54 PM
tdpower
tdpower's Avatar
I had the same problem. Turned out to be a bad solder joint. Same one in your link.
tdpower is offline
Old 11-27-2010, 02:26 AM
DigitalTrixx
Cool. Going to see if that is the issue Tuesday with some friends. Hope it is the problem if I take apart my whole gauge cluster =\.
Old 11-27-2010, 12:24 PM
tdpower
tdpower's Avatar
It's worth a try. Here are the instructions for pulling the cluster: http://www.americanmuscle.com/mustan...es-how-to.html
Also, the bad solder joint was hard to see with the naked eye. I used a magnifying glass.
tdpower is offline
Old 12-05-2010, 08:09 PM
kristynnn
kristynnn's Avatar
this happens to my 2000 too!
Only for a few seconds though, it always comes back on.
kristynnn is offline
Old 12-05-2010, 11:48 PM
tdpower
tdpower's Avatar
If you were closer I would pull your cluster. Maybe some of the other guys can help.
tdpower is offline
Quick Reply: My odometer randomly stops working? =[
