convertible latch rattle
Old 12-09-2010, 10:08 PM
timk
timk's Avatar
Default convertible latch rattle
hi all. i have a 2010 convertible. the top latches at the windshield header are very noisy, naturally even more so over bumpy pavement. the top is very snug, with no wind noise issues or leaking.
it's winter now, so i'm sure i could just slice up some small bits of bicycle inner tube and slide them in to shut them up, but i would like a long-term solution.
thanks in advance.
timk is offline
Old 12-09-2010, 11:15 PM
jpormen
jpormen's Avatar
Im guessin its still under warrenty, try taking it to the dealer and see what they say. If the dealer is near you that you bought it at and u got some free time, couldnt hurt to stop in.
jpormen is offline
Old 12-10-2010, 12:11 PM
timk
timk's Avatar
ah, that's the kicker. it has 37k on it. anyway, i'd like to do this sort of thing myself, as spending time in a dealership is one of my least favorite things to do.
timk is offline
Old 12-26-2010, 12:33 PM
tailwind
tailwind's Avatar
Had a similar problem on our 2006 and in taking the latches apart I found there are shims and I just took enough shims out to tighten things up. Also found that the small rollers on the latches were stuck so some oil and a little working the roller cured that. Hope this helps you.
tailwind is offline
Old 01-08-2011, 10:48 PM
timk
timk's Avatar
thank you, i will try that. seems simple enough!
timk is offline
Old 01-09-2011, 09:49 PM
kc5mhb
kc5mhb's Avatar
After I had the top replaced twice under warranty, mine started making a rattling noise going over bumps. What I found was the stiff section in the front of the top that kinda feels like stiff cardboard or plastic, if I put pressure upward on the passenger corner, the noise stops. Now the driver's side is doing it sometimes. Maybe its the same thing but it drives me crazy and I'm out of warranty. I keep thinking the top shop didn't do something else they were supposed to do.
kc5mhb is offline
Old 10-20-2011, 03:34 PM
asoka05
asoka05's Avatar
hi OP,
did you manage to figure out how to stop the rattle?
My 2010 V6 convertible seems to be having the same rattle as yours. Mine is coming from the driver side.
I would bring it in to the dealer because it is still ~30k miles, however its a big PITA because they don't work on cars on Saturdays (besides doing oil change).
Does anyone have the same rattling problem on the 2010 and up convertibles ?
asoka05 is offline
Old 10-20-2011, 10:43 PM
timk
timk's Avatar
i never did anything about it. once the weather warmed up, it was much quieter. you know how much noise your car seems to make when it's cold? not so much when it was warm. i still need to look into it, though.
timk is offline
Old 02-22-2014, 08:43 PM
ParkerSoCal
ParkerSoCal's Avatar
On my 08 the latches seemed to get loose with age. I had ticking noises, rattles, and I even thought one of my windows was rattling on large bumps. After trying many different things, this finally fixed it for me: Went to Lowe's and bought 3 packets of 2 ea rubber grommets (5/8x5/16). They're in the pull-out drawers in the hardware section. Stacked 3 grommets on each connecting post. Now everything is drastically tightened and almost no rattles! A total of $4 so it's worth a try. Not sure if the 10-14 year models are different. Good luck!
Attached Thumbnails convertible latch rattle-img_0446.jpg   convertible latch rattle-img_0447.jpg   convertible latch rattle-img_0449.jpg
ParkerSoCal is offline
Old 11-09-2016, 05:06 PM
Xtinestang2010
Xtinestang2010's Avatar
Default WD 40
thanks in advance.
I kniw im years late to this post! But i was looking for a fix for this same issue and stumbled upon this thread, and WD40 on the latch handle joints did the trick! No squeeking or ticking anymore! Sorry im soooo late im new to this.
Xtinestang2010 is offline
Quick Reply: convertible latch rattle
