Edelbrock 1806 Tuning
Old 12-27-2010, 02:46 AM
tx65coupe
tx65coupe's Avatar
Default Edelbrock 1806 Carburetor Tuning
My 65 is still running a little rich. It has an Edelbrock 650 Thunder AVS carb. Its enough so that I get fuel residue on the outside of the exhaust tips and the bumper gaurds. The car runs really well though. I got this calibration kit. I think the jets need to be downsized a step. What size comes in it out of the box? Does anyone have any tips or advice for me?
http://www.summitracing.com/parts/EDL-1840/
tx65coupe is offline
Old 12-27-2010, 08:32 AM
Starfury
Starfury's Avatar
You can't use the exhaust pipes as a gauge for how the engine is running. The engine is always running rich when you first start the car, so you'll likely always get some soot out the tailpipes.
Pull a plug and use that as a reference point. If it's black and sooty, try a rod with a bigger large (cruise mode) diameter. If it's white, go with a smaller diameter.
Starfury is offline
Old 12-27-2010, 04:36 PM
tx65coupe
tx65coupe's Avatar
After I go somewhere I can wipe my finger inside the tail pipe and my finger is damp and sooty. There is raw fuel inside the tail pipe. I went on a 20 mile drive to my friends house and after I got there we did this test and got the same results. It was a warm day too.
I've never had a car leave fuel residue on the bumper gaurds before.
The exhaust always smells rich even when its hot outside and the car is warmed up. Alot of people comment that the fumes are too strong. You can't stand anywhere near the rear of the car while its running for more than a minute or your eyes will burn.
I have looked at the plugs and they look fine.
I have also checked the choke multiple times and it is working properly.
Fuel pressure is 6 psi.
Here is a quick question. How long should it take the fuel pressure to bleed down after the engine is turned off?
Old 12-29-2010, 04:38 AM
tx65coupe
tx65coupe's Avatar
I was thinking about getting this Edelbrock 6593 air fuel ratio tool. I looked at the instructions and it says that it is supposed to be installed. I would rather use it as a temporary diagnostic tool.
http://www.summitracing.com/parts/EDL-6593/
Old 12-29-2010, 05:02 AM
gconnsr
gconnsr's Avatar
Check the secondary lower butterflies and make sure they're closing all the way, if they're not the secondaries will drip.
gconnsr is offline
Old 12-29-2010, 06:24 AM
Stangatic
Stangatic's Avatar
Dude, Edelbrock carbs are definitely not performance out of the box! I have the same carburetor and had the same problem. I used a vacuum gauge and did all of the above mentioned stuff with no avail. I just ended up taking my car to a dyno shop where the carb accounted for a 100hp loss to the rear wheels. The guys at the shop tuned the car by going to larger jets all around (Sorry I don't know what size they used). And the also changed out the metering rods twice. The Carb now runs like a million bucks.
Take the car to a dyno or do it the old fashion way of trial and error.
Stangatic is offline
Old 12-29-2010, 08:40 AM
Starfury
Starfury's Avatar
Damp tailpipes don't mean anything either. Water is a natural byproduct of combustion.
But if it's smelling rich, then yes, something's definitely wrong. Doesn't mean it's your cruise mode, though, and the clean plugs support that. Could be your step-up springs are too soft (I'll cover that in a minute), or could be the power mode is too rich. And at idle you tune with the idle mix screws. The jets and rods don't really affect idle mix.
First thing's first, set the timing properly. If your timing's off, you'll be chasing your tail forever trying to get the carb dialed in. 8-10* initial, 30-34* total, all in by ~3k. That should get you in the ballpark.
Once the timing is set, set the idle mix. A vacuum gauge really helps here, but you can do it by ear as well. Once the idle mix is set, then worry about tweaking the rods/jets.
The one problem that I seem to notice with these carbs out of the box is that they tend to come with 7" step-up springs, which is a bit soft for many performance motors. The power mode kicks in too early, drawing too much fuel into the motor before it needs it. Drop a 4" or 5" spring in and it may help things a little.
Starfury is offline
Old 12-29-2010, 07:09 PM
FlyByNight
FlyByNight's Avatar
I've seen this happen on Edelbrocks and had to tweak the secondary linkage, easy fix. Rear butterflies were opening a hair at idle do to slop and dripping.
FlyByNight is offline
Old 12-30-2010, 05:01 AM
tx65coupe
tx65coupe's Avatar
I did not even think about that being a possible issue.
Old 12-30-2010, 08:16 AM
kalli
kalli's Avatar
Yes if the eyes are stinging you are dumping raw fuel. First thing you need to do is get correct fuel pressure. 4.5 psi is what those edelbrocks want. Not 6. Use a regulator. Once that is done check float levels and what was said about the secondaries. Your floats might be stuck. You usually see that when fuel drips out of the boosters. If you gave a vacuum gauge use that to set mixture and step up spring like starfury said.
kalli is offline
Quick Reply: Edelbrock 1806 Tuning
