alternator clutch pulley
Old 12-28-2010, 11:58 AM
elnorte
elnorte's Avatar
Default alternator clutch pulley
I bought an aftermarket alternator, and didnt realize that it didnt have the clutch pulley. Every time I shift gears, it squeals. NTO sells alternator clutch pulleys. Am I able to take off the standard pulley and install a clutch pulley, or do I have to buy a new alternator all together? thanks
elnorte is offline
Old 12-28-2010, 02:45 PM
157dB
Cut & Paste Expert
157dB's Avatar
If the shaft fits, it can be swapped with the old OEM clutch pulley.
If it is of a different size, its a no go without an adapter.
You bought or they sold you the wrong alternator.
Take it back and get the right one.
www.PAPerformance.com FTW.
157dB is offline
Old 12-28-2010, 03:48 PM
elnorte
elnorte's Avatar
It's for the mustang and says its not a clutch pulley alternator. Anyone know how I get the old pulley off? Looks weird. lol
elnorte is offline
Old 12-29-2010, 04:13 PM
157dB
Cut & Paste Expert
157dB's Avatar
An alternator pulley puller, maybe?
157dB is offline
Old 01-01-2011, 03:05 AM
CityDave
CityDave's Avatar
Here is a link for a removal tool that is used on the clutch pulley.
http://www.denlorstools.com/home/dt1..._tool_set.html
They have a video showing how to use the tool. I will be buying one being I have to replace about 10 alt a year on my PD units due to the clutch pulley wearing out
. Dont worry that the kit shows it fits a VW, it also shows Ford on the list of alt. it will fit.
I also found a pulley for around $68.00
Hope this helps
Dave
CityDave is offline
Old 01-02-2011, 12:43 PM
elnorte
elnorte's Avatar
Hope this helps
Dave
Thanks Dave! I noticed New Take Off has them for around $15 or so
elnorte is offline
Old 01-04-2011, 02:10 PM
Burt
Burt's Avatar
Ya I also found a new one for about 69. They have the dimensions which could help you if you still arent sure.http://www.americanenginesco.com/ser...ANG-CAR/Detail
I would assume from the price difference that one is original and one is not. That happens a lot these days with all the Chinese junk going around. Good luck!
Burt is offline
Old 01-11-2011, 06:24 PM
CityDave
CityDave's Avatar
Here is a link to a good write up on how the pulley clutch works.
http://www.denlorstools.com/autoblog...pe-alternator/
CityDave is offline
GimpyHSHS
19
12-19-2023 01:12 PM
4cylinderplus2
10-09-2020 07:45 PM
Thunderball
15
11-22-2015 11:49 PM
junior04
09-28-2015 10:53 AM
MacSerio
09-27-2015 01:05 PM
Quick Reply: alternator clutch pulley
