Power Steering Whine
Got an 03, Convertible with the V6. It has what I've heard is a common problem, noisy whine from the Power Steering pump. I've been told by three different shops and the local Ford dealer that changing the pump may or may not fix the problem. I have read on several sites that it is no easy thing to correct and some have even changed the Steering Rack to make the steering Manual. The Steering, itself, is fine, smooth and responsive.
I'm too old and too poor to do something like a major change of hardware. I tried Lucas, no help. I've tried full replacement with the Valvoline Synthetic PS Fluid, it helped, some. I have heard, just recently, that M&B TrickShift, Original, ATF has been known to work very well.
Does anyone have experience with this Fluid as a Fix???
Any Help would be greatly appreciated.
Ford specs ATF in all of their power steering racks. Had a brother in law with a Ford F250, and a noisy PS pump. I did a complete swap of the fluid, poured in Amsoil Synthetic ATF, and the noise was gone. The second benefit was how much easier it was to turn the steering wheel while not moving. He was stoked! My advice is to pull a hose, start up the car, and get most of the fluid out of the rack. Refill, done. Did my 2008 GT as well, and soon to do the 2009 Shelby.
3 days and so far it looks good
It's been 3 going on 4 days since I changed fluid, as much as I could with a turkey baster and the somewhat cumbersome remove, replace, run, rotate the steering wheel, remove, replace, run, rotate the steering wheel method. I put in a total of 2 quarts of M&B TrickShift Original. I still have 1 quart and, when the weather warms, I may add it using the same method. I have had a reduction in the whine. When first started, the whine is very audible at idle but shortly begins to quiet and continues to do so as the engine, and steering fluid warms. It is not heard while driving, which a great improvement and barely detectable at idle. I feel I'm hearing it because I am listening for it.
I think the jury is still out as to this being the end all be all but it is sure better by far.
I did a complete service on a 2005 Trailblazer today. GM recommends power steering fluid for their racks. Just for experimental purposes, I tried Amsoil ATF. The truck did not like this at all. The PS pump whined terribly. I flushed the system and poured in power steering fluid, and it was silent again.
Weird, Ford is exactly the opposite. I seriously want to know what the difference is between the two racks.
Boil Over?
That's strange. Is there any possibility the O'Ring seal around the cap is missing and it is just slopping out versus boiling out? I've added a gasket between the lip of the Reservoir and the flange of the cap because the fit is loose.
During my quest to find an answer to my Whine, I over filled the reservoir, a little, and some of that forced it's way out, over the course of a week or so. I noticed spotting on the garage floor and determined I had too much fluid in the thing. Good luck on that.
I'm looking to sell my 03 and the whine was troubling from a perception point of view. The steering has always functioned smoothly.
