COP conversion on high hp builds?
Old 02-10-2011, 05:11 PM
97stanger
97stanger's Avatar
Default COP conversion on high hp builds?
Hey guys, my motor is going in the car next week, but with all these coil packs/spark plug wires running all over the motor its very convincing to convert to COP. There is a guy on corral who sells the harness needed and he has COP's for a good price. Just wanted to check, has anybody tried this conversion with higher hp motors? nothing at all is wrong with my coil pack/wire setup, its just a mess and looks soooo much cleaner with COP. Just wanted to see if this conversion could cause any sort of problem on higher hp motors or anything I should watch out for?? Thanks
Mike
97stanger is offline
Old 02-10-2011, 06:47 PM
tbirdscwd
tbirdscwd's Avatar
There is nothing wrong with that conversion harness. If anything it will deliver a more consistent spark to each cylinder and less likely to have issues because the high voltage responsible for ignition is only traveling down a short metal coiled wire vs through a series of spark plug wires.
tbirdscwd is offline
Old 02-11-2011, 10:20 AM
devongarver
devongarver's Avatar
What he said^
devongarver is offline
Old 02-11-2011, 11:47 AM
97stanger
97stanger's Avatar
I just dont like the idea that I spoke w/ the maker of this harness and he seemed clueless about his product. " I cant guarantee this product on your hp leverl, I have a few members running around that level but will not guarantee it above 500hp, due to variables"
Also, after just putting together my blower/8 rib pulley setup and i would have to take everything back apart to remove the coil pack brackets...no thanks
Thanks though guys
Old 02-11-2011, 07:40 PM
Sxynerd
Sxynerd's Avatar
I did the conversion. I did everything right and I still had issues at 6500rpm+. If I had kept CP & wires I really believe I wouldn't have had any issues.
I think there is a reason you don't see COP's in high RPM, & High HP race cars. If I had it to do again, I would not have done it.
That said, It did look good.
Sxynerd is offline
Old 02-13-2011, 06:27 PM
97stanger
97stanger's Avatar
thanks for the input, your not the first guy that has told me this now...I'll definitely be sticking w/ cp's and wires...thanks again
Old 02-13-2011, 09:30 PM
Z28KLR
Z28KLR's Avatar
Originally Posted by Bladerunner
If you do the COP conversion it's a great excuse to run aftermarket COP's.
Why would you run any aftermarket cop's when they're no better (and typically less reliable) than the oem ones?
Z28KLR is offline
CS2007
06-25-2019 09:45 PM
svfetter
10-05-2015 11:39 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
Drastang
09-30-2015 03:48 AM
Quick Reply: COP conversion on high hp builds?
