Automatic Clutch Adjustment?
Old 02-25-2011, 02:34 PM
MustangLouver
MustangLouver's Avatar
Default Automatic Clutch Adjustment?
My quadrant seems to be in good shape, pulled up on the pedal, pushed down to the floor to adjust, clutch adjust, but when the pedal is all the way out, it makes a god awful rattle/squeak. The TOB is brand new. The local transmission shop looked at it, tried to adjust it, and never had any luck. He said what's happening is, the fork is touching the flywheel, and once the grease wears that he applied, it starts making the noise again. The clutch, new bearing only have 900 miles on them. He suggested that I get a firewall adjuster and get rid of the automatic adjuster. MM has the kit for $130. The shop owner said he has had quite a few new edge mustangs in with the same problem.
Is there a TSB for this issue? Any suggestions on what kit to buy?
MustangLouver is offline
Old 05-16-2011, 10:05 PM
95SHO
95SHO's Avatar
Any fix for this?? I am having the same issue, new clutch, throw out bearing and pilot bearing and when the clutch pedal is released it makes the same noise. If I touch the pedal just slightly it goes away.
95SHO is offline
Old 05-16-2011, 10:09 PM
MustangLouver
The problem was fixed for me by putting in a manual firewall adjuster. Cost me around $150 labor and all. The kit my guy ordered had a new cable, quadrant, and the firewall adjuster. If you do get this done (Which I would highly recommend, as the transmission shop said the rubbing caused my premature T.O.B. failure) then expect to have about 200 miles where the clutch is INSANELY hard to press in. Lol. I promise, it breaks in soon enough.
Old 05-16-2011, 11:45 PM
95SHO
95SHO's Avatar
Do you know where they got the kit from??
95SHO is offline
Old 05-17-2011, 07:18 PM
MustangLouver
Im pretty sure he said he ordered it from Jegs
Old 05-17-2011, 07:27 PM
kugzgt
kugzgt's Avatar
i got the same problem man, my pedal rattles like crazy sometimes, i have a new cable, just waiting on the firewall adjuster and quadrant
kugzgt is offline
Old 05-17-2011, 07:36 PM
MustangLouver
Good luck. It fixed all my clutch problems and its so much smoother shifting now.
Thunderball
15
11-22-2015 11:49 PM
b8checker
10-08-2015 12:55 PM
b8checker
09-30-2015 07:11 AM
wraith777
09-28-2015 10:49 AM
lincolnshibuya
09-24-2015 10:46 PM
Quick Reply: Automatic Clutch Adjustment?
