Last edit by: IB Advertising
Browse all: Exterior
- Ford Mustang V6 1994 to 2004 How to Replace Door Hinges
Step by step instructions for do-it-yourself repairs.
Replace Door Hinges
2004 Mustang Door Hinges
Ryan,
I did check at a Ford dealership for the pins and bushings and they told me that they were not available. That is why I ended up buying the hinges instead. I also checked with Advance Auto and they could not get the pins and bushings either. I will try a different dealership for the pins and bushings to see what happens.
Thanks,
MWSTANG99
Thanks,
MWSTANG99
I have yet to find a dealer that sells pins and bushings for the 94+, but they are not sealed units, you can get the pins for a Fox and drill the hinges slightly, a little bit of a pain, but much cheaper.
99-04 models
For year models 99-04 Coupe (i did not check convertibles) you have to replace the entire hinge. For some reason, these models do not come with removable pins/bushings. It is an all-in-one deal. They run about $35 for the top one and $55-60 for the lower (the one with the rubber roll).
Like some others have posted, you could modify the current hinges to allow for the older pins and bushings to work, but personally I feel mods only bring more problems.
Hope this helps.
-Joaquin I.
Hope this helps.
-Joaquin I.
