Changing coolant on a 95
Old 03-20-2011, 09:54 AM
ryan_89_mustang
ryan_89_mustang's Avatar
Default Changing coolant on a 95
I am wanting to change my coolant because the previous owner put the red stuff in it. I have never done this on any vehicle before. I have looked up some how to's and what not but I am still unsure. Is is necessary to flush the coolant, or could I just drain everything somehow and refill?
ryan_89_mustang is offline
Old 03-20-2011, 10:33 AM
AdderMk2
AdderMk2's Avatar
on the passenger front side of the block, there is a allen head plug. This is your main block drain. Remove it, with the radiator cap off. the block will drain out. On the bottom of the radiator, there is a petcock that will allow you to drain the rad itself. Once both are drained, close up both holes.
fill the engine with straight water. run it for a few minutes and drain it again, just like before.
Once everything is all closed up, refill the car with a 50/50 coolant/water mix.
AdderMk2 is offline
Old 03-20-2011, 11:24 AM
jlc41
jlc41's Avatar
What AdderMk2 said, and repeat until the water is clear. When I had my shop I would put a hose in the radiator and run engine till all water flowed clear. Plus don't forget to put the heater on so you get the old coolant out of it.
jlc41 is offline
Old 03-20-2011, 12:30 PM
AdderMk2
AdderMk2's Avatar
you dont need to put the heater on. It isn't valved, like a chevy.
AdderMk2 is offline
Old 03-20-2011, 01:18 PM
ryan_89_mustang
Thanks adder. I can just use regular water for the flush right? I have read things where it says to only used distilled water or whatever.
Old 03-20-2011, 01:50 PM
TrimDrip
FudgeDrip
TrimDrip's Avatar
You can just refill too if it is not causing problems. Go to the parts store and ask for universal antifreeze. Although, I do believe that Ford antifreeze causes probelms after buying three 95-98 model engines for my dad's car and all of the aluminum heads being rurnt from corrosion of antifreeze.
TrimDrip is offline
Old 03-20-2011, 03:31 PM
Five0hFox
Five0hFox's Avatar
Not only Chevy does that, my Explorer has it.
Five0hFox is offline
Old 03-21-2011, 08:36 AM
jlc41
jlc41's Avatar
Question Flush
So it's a flow thru with a baffel door to isolate the heater until you need it???
jlc41 is offline
Old 03-21-2011, 09:10 AM
AdderMk2
AdderMk2's Avatar
yes. flow there is constant
AdderMk2 is offline
Old 03-21-2011, 09:31 AM
jlc41
jlc41's Avatar
Thanks AdderMk2, leran something every day.
jlc41 is offline
Granatelli Sales
01-20-2020 12:34 AM
Dathan
10-05-2015 05:52 AM
wraith777
09-28-2015 10:49 AM
lmurf60
09-24-2015 10:07 PM
MusicCity615
09-12-2015 07:05 AM
Quick Reply: Changing coolant on a 95
