Lumpy Torque Curve. Normal?
Old 03-27-2011, 02:55 AM
Swervin309
Swervin309's Avatar
Default Lumpy Torque Curve. Normal?
I did a dyno run after flashing a new tune (Brenspeed) that was updated for the new mods. Numbers were 291 @ 5400/308 @ 4400 (275/294 previously). I noticed that the torque curve was rather lumpy and would spike and flatten for a few hundred RPM. Is this normal? Tuning? Or am I retarded? Thanks guys.
Swervin309 is offline
Old 03-27-2011, 03:11 AM
Tylus
Tylus's Avatar
what are your mods?
LT's with cat delete? if so, ensure the rear O2's are turned off
Tylus is offline
Old 03-27-2011, 03:13 AM
Swervin309
Swervin309's Avatar
BBK CAI, BBK 62mm TB, Shorties, Dynomax Ultra-Flo Welded muffs, 91 tune.
Old 03-27-2011, 12:04 PM
Tylus
Tylus's Avatar
Check for air leaks on your Cai and TB. That can cause wierd spikes
Not bad numbers otherwise for relatively unmodded. How was your A/F ratio?
Tylus is offline
Old 03-27-2011, 12:15 PM
Swervin309
Swervin309's Avatar
No leaks. I checked everything before I pulled.
Not sure. I haven't put a wideband on it yet. Although she did like being "2% richer".
Old 03-27-2011, 12:16 PM
SpartaPerformance
SpartaPerformance's Avatar
No it's not normal at all. Your torque and HP curves along with your AF ration should be as smooth as possible.
SpartaPerformance is offline
Old 03-27-2011, 12:22 PM
Swervin309
Swervin309's Avatar
Old 03-27-2011, 03:22 PM
Simon1
Simon1's Avatar
Is this an automatic?
From the looks of the run I would say something off on the dyno.
What did the shop say?
Simon1 is offline
Old 03-27-2011, 04:13 PM
Swervin309
Swervin309's Avatar
Nah, it's a 5.
The shop didn't say anything other than "Your HP curve looks smooth". I gives a s*** about HP.
Old 03-28-2011, 10:36 AM
Simon1
Simon1's Avatar
I torque curve like that would be felt by the driver and probably heard from those listening. Point to the spot on the graph and say WTF? What is that? Make them explain.
Simon1 is offline
lincolnshibuya
12-08-2015 04:37 PM
breaking
10-02-2015 01:27 PM
guitarman376
09-30-2015 05:54 PM
wraith777
09-28-2015 10:49 AM
LivingInThePast
09-16-2015 12:20 PM
Quick Reply: Lumpy Torque Curve. Normal?
