Pressure plate Torque specs??
Old 04-18-2011, 12:48 PM
Mustang5090
Mustang5090's Avatar
Default Pressure plate Torque specs??
Hey guys just wanna double check what is the proper torque Specs for the pressure plate bolts and the flywheel bolts? 1990 5.0 with a t-5 conversion stage 3 clutch
Mustang5090 is offline
Old 04-18-2011, 12:55 PM
tohoopty
tohoopty's Avatar
dont know about the fly wheel but the pressure plate bolts are 35 ft lbs
tohoopty is offline
Old 04-18-2011, 07:09 PM
nitrous_bob
nitrous_bob's Avatar
well i wanted to say like 25 on the PP and 75 on the flywheel. but thats from memory only
nitrous_bob is offline
Old 04-18-2011, 09:49 PM
Bubba 95SN
Bubba 95SN's Avatar
75-85 ft lbs for flywheel, put thread sealant on flywheel bolts or oil will leak past threads. Stock pressure plate is 12-24 ft lbs.
Bubba 95SN is offline
Old 04-19-2011, 09:28 AM
stdyhand
stdyhand's Avatar
Oddly enough the Chilton manual only shows the 2.3l, but it says 54-64ft. lbs for the flywheel and 15-24ft. lbs. for the pressure plate.
stdyhand is offline
Old 04-19-2011, 06:46 PM
TrimDrip
FudgeDrip
TrimDrip's Avatar
I use a 3/8" impact on the on the flywheel bolts, which is about 75lbs on my gun. The pressure plate, I just torque them down evenly. and go over them a few times to make sure they are all the same. I probably go 20 to 25 lbs. Never had a problem.
TrimDrip is offline
baddog671
07-26-2016 01:20 PM
mdg
10-01-2015 07:04 AM
winner99
09-30-2015 07:04 PM
guitarman376
09-30-2015 05:54 PM
wraith777
09-28-2015 10:49 AM
Quick Reply: Pressure plate Torque specs??
