4.0 throttle body upgrade?
Old 04-18-2011, 11:06 PM
Jasoon
Jasoon's Avatar
Default 4.0 throttle body upgrade?
Hey sixers,
One of the power upgrades available for my Dakota 4.7 was a larger diameter throttle body. However, I haven't seen one for the 4.0 V6. Are they not available?
Has anyone bored out their own?
Thanks
Jason
Jasoon is offline
Old 04-18-2011, 11:11 PM
obxdude018
obxdude018's Avatar
There are some aftermarket upgrades out there, they are not worth the value to performance however, boring the stock one out might be the cheaper route
obxdude018 is offline
Old 04-19-2011, 03:21 AM
bronxbomba63
bronxbomba63's Avatar
There's a guy that bores out the 4.0 TB's on ebay, but I don't remember his name. You can buy one from this company called Zabtek. There's also one from BBK, but all I've heard from people who have that one is that it gets stuck open at times.
bronxbomba63 is offline
Old 04-19-2011, 06:06 AM
JimC's Avatar
Jerry Stranigan is the guy who ports and polishes the stock throttle body. I sent mine to him to be worked on so here's some pictures comparing the stock (I have an extra one off an '05 in the garage) to the Stranigan port and polish one:
A friend tested it on his flow bench and it flows quite a bit more than stock. Since it is the stock throttle body there aren't any issues once you put it back on like the BBK seems to have.
JimC is offline
Old 04-19-2011, 06:15 AM
2005Redfire6
2005Redfire6's Avatar
I'm thinking about getting the same one Jim posted, usually you can find that one or a similar ported/polished on eBay for around $80.
2005Redfire6 is offline
Old 04-19-2011, 10:33 AM
pbfoot
pbfoot's Avatar
The bore in the intake is just a little larger than 65mm.Do not see that a larger throttle body would do much good without modifying the intake.I have seen aftermarket 70mm throttle bodies but do not remember the manufacturer.
pbfoot is offline
Old 04-19-2011, 10:45 AM
2005Redfire6
I believe Zabteck is a 70mm.
Old 04-19-2011, 04:44 PM
JCON
JCON's Avatar
Go with the polished TB, I've heard a lot of issues with aftermarket TB's on our cars failing. I am hoping to sell my V6 and get a GT instead but one of my planned upgrades was Jerry's polished TB. If i keep the six, I will buy one from him. Heard nothing but great things about them.
JCON is offline
Old 04-19-2011, 09:18 PM
Jasoon
Jasoon's Avatar
So how do I get in touch with Jerry ?
Jasoon is offline
Old 04-19-2011, 09:59 PM
JCON
JCON's Avatar
Hes 618jerrys on ebay but I just sent hi ma message asking about preferred contact methods. I'll post when i get the info
JCON is offline
Quick Reply: 4.0 throttle body upgrade?
