Coolant leak---HELP!!
Old 04-23-2011, 08:19 PM
08svt
08svt's Avatar
Default Coolant leak---HELP!!
I have a '92 LX vert 5.0. I have a coolant leak that is down the back left side of the block. I so far have done head gaskets/intake gaskets. It is not a bad leak. But enough to notice and smell. Anyone have any ideas of what else it can be. I am at a loss at this point to get it to go away
08svt is offline
Old 04-23-2011, 09:55 PM
nightmare90gt
nightmare90gt's Avatar
heater lines
nightmare90gt is offline
Old 04-24-2011, 07:11 AM
08svt
08svt's Avatar
Which ones?
08svt is offline
Old 04-24-2011, 09:35 AM
nightmare90gt
the ones located on the back of the intake manifold. follow all you hoses
Old 04-24-2011, 10:51 AM
jlc41
jlc41's Avatar
Am not sure but you may have a freeze plug in that area.
jlc41 is offline
Old 04-24-2011, 01:36 PM
rtintwo
rtintwo's Avatar
Heater hose, gasket or crack.
Take a mirror and a flashlight and give everything a good look till you trace it back to the exit point.
rtintwo is offline
Old 04-24-2011, 08:11 PM
Bubba 95SN
Bubba 95SN's Avatar
Freeze plug is in rear of head. Get pressure tester, pump to 16lbs while cold, have a look see.
Bubba 95SN is offline
Old 04-25-2011, 07:46 PM
08svt
08svt's Avatar
I have already replaced the head gaskets, and when they were done I had the heads sent and and tested.
Leak only happens when engine is hot, once it cools down nothing shows up on pressure test. I added some dye today hoping that helps
08svt is offline
Old 04-26-2011, 07:59 AM
jlc41
jlc41's Avatar
Default leak
Not to sound disrespectful, but you did follow the torque sequence and torque on the head bolts????. I say this because in the late 70's when Olds come out with the diesel they had head bolt problems. Turned out to be rear head bolt holes weren't tapped out deep enough, go figure.
jlc41 is offline
Old 04-26-2011, 10:18 AM
DGSipes
DGSipes's Avatar
I had the same issue...turned out to be the heater core hoses (there are two of them...send and return)...my hose clamps were cranked down too hard. You would only see the leak if the engine was hot and at the same time giving it some gas...use your hand and manually rev the engine using the throttle body and shine a flash light back to those hoses to check and see if they are leaking....make sure then engine is at operating temperature.
DGSipes is offline
Quick Reply: Coolant leak---HELP!!
